Rust!
Tower Hobbies
Logged in as Guest
  Printable Version
Team Losi Muggy - RTR
Seller:  PastorVee
Details:   $1,100.00   |  10/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> Rust!
Page: [1]
Login
Rust! - 7/5/2008 11:36:44 PM
SycoCell
Status: offline
How do I keep rust off of my CV, link, screws...everything! on my 8ight-T???
_____________________________
"I seemed to hit a speed bump!"
"No, that was just his Revo!"
       Post #: 1
RE: Rust! - 7/6/2008 12:22:07 AM
Tree1
Status: offline
After you clean your rig, wipe everything down with WD-40.
Nomadio Sensor, Cen Matrix FRE/GO TECH .21 7P, Cen TR Arena FRE/GO TECH .21 5P, "N-Tune" Nitro Engine Tuning Dials
(in reply to SycoCell)
       Post #: 2
RE: Rust! - 7/6/2008 12:45:10 AM
SycoCell
Status: offline
okay sweet. any ideas on how to get rid of some of the rust I have now? I accumulates from my aircompressor..it's so humid here that it sprays out water. and last night didn't help the fact.
(in reply to Tree1)
       Post #: 3
RE: Rust! - 7/6/2008 1:00:13 AM
madmax22
Status: offline
umm maybe take VERY fine sandpaper or steel wool to the parts and scrape it off... for the bolts its pretty much to late.... maybe soak them in WD-40 for a couple days but i dont think it will help...
They call me "butthead".......
       Post #: 4
RE: Rust! - 7/6/2008 4:02:36 AM
Tree1
Status: offline
quote:
ORIGINAL: SycoCell
steel wool will help the cvds for the bolts, I'm not too sure about the bolts. You should buy a water trap for you air compressor. That will prevent water droplets from coming out of the hose/nozzle when in use.
       Post #: 5
RE: Rust! - 7/6/2008 4:07:56 AM
SycoCell
Status: offline
Oh. I never knew there was anything I could buy for the water. I was actually thinking on bring my compressor inside the house where it's A/C. That should limit the water emissions.
(in reply to Tree1)
       Post #: 6
RE: Rust! - 7/6/2008 4:27:42 AM
Tree1
Status: offline
The cooler temps will helps with some of the condensation. What kind of air compressor do you have? Most air compressors have a drain plug at the bottom of the tank so that you can drain any water/condesation from the tank.
If you use an oil free compressor you can purchase some thing like this:
http://greenvalleycompressor.com/miva_apps/mm5/merchant.mvc?Screen=PROD&Store_Code=PT&Product_Code=AF3WT1&Category_Code=RWAOT
If you use an air compressor which needs oil then you can use something like this one.
The water traps are a necessity if you are going to paint. Shop around you may be able to find then cheaper.
< Message edited by Tree1 -- 7/6/2008 4:28:28 AM >
       Post #: 7
RE: Rust! - 7/6/2008 4:41:00 AM
mabuecker
Status: offline
I use an air dryer like the one a paint shop would use ... or you can go to napa(or auto paint suppy store)and get a toilet paper roll(usually black or orange smaller than a fist type of ball)and put it on between the hose and the blower nozzle itself ... wd40 the heck out of everthing then wipe down nicely ... my buggys like to hang out right beside me and my recliner with air conditioner to keep comfortable and avoid the humidity seriously they do . . .
l o s i 8 roller rossi 21-jp3 z9100ts losi alum & 8t roller werks 28-dynamite053 z9100ts khz alum
(in reply to Tree1)
       Post #: 8
RE: Rust! - 7/6/2008 5:17:06 AM
Burntt32
Status: offline
as posted above, use a water trap. they are a necessity for compressors especially if you are airbrushing.
Air: Align 450 SEV2
Ground: currently vehicleless :(
(in reply to mabuecker)
       Post #: 9
RE: Rust! - 7/6/2008 1:19:55 PM
SycoCell
Status: offline
Yeah i don't do any painting. My air compressor is about 25 years old. It's my father's. It works like a charm though. Doesn't have one of those stupid tanks. It just flat out turns on and pumps out 100psi constant. But i appreciate the input guys!
(in reply to Burntt32)
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
