Hull Force tunnel hull
Tower Hobbies
Logged in as Guest
Users viewing this topic: cnchobby
  Printable Version
All Forums >> RC Boats >> RC Airboats >> Hull Force tunnel hull
Page: [1] 2   next >   >>
Login
Hull Force tunnel hull - 7/6/2008 3:46:49 AM
mjderstine
Status: offline
well here is an update on the hull i have been building. its 40" long 21" wide, and will be powered by a OS 1.08
here are the updated pics of the hull. hope you all enjoy.
it will have a water rudder, and i hope to get some nice top speed runs outta this thing. my goal is about 40mph, but with a 1.08 i dont think that much speed will be a problem. the motor will be mounted upside down to keep the CG as low as possible.
< Message edited by mjderstine -- 7/6/2008 3:47:40 AM >
_____________________________
www.tamiyatamtalk.com moderator
GB01 X 2, tb02, tb05, m03, clodbuster, twin force, raider
       Post #: 1
RE: Hull Force tunnel hull - 7/6/2008 10:15:51 PM
mjderstine
Status: offline
(in reply to mjderstine)
       Post #: 2
RE: Hull Force tunnel hull - 7/7/2008 3:28:25 PM
Mr Cajun Gator
Status: offline
best of luck to you, may the winds be on your side
Catch a Gator by the Tail and hang on for the Ride!
Cajun Gator Airboats, M.AB.A
       Post #: 3
RE: Hull Force tunnel hull - 7/22/2008 4:42:54 AM
shinobid
Status: offline
That things pretty awesome!! Got any more pics?
(in reply to Mr Cajun Gator)
       Post #: 4
RE: Hull Force tunnel hull - 7/22/2008 5:54:29 PM
mjderstine
Status: offline
i have lots more of the build. anything in particular you would like to see?
(in reply to shinobid)
       Post #: 5
RE: Hull Force tunnel hull - 7/22/2008 7:09:25 PM
shinobid
Status: offline
Just curious about how it's looking now..whats the color scheme going to be?
       Post #: 6
RE: Hull Force tunnel hull - 7/22/2008 7:29:47 PM
mjderstine
Status: offline
the whole hull has been painted white, and will have some orange accents to start. i have about 6 coats of automotive acrylic paint on there, but want another couple coats to get it nice and waterproof. then i can start laying some color on top of the white.
i have another thread of the build of this boat. just look further down the page for all the build pics.
       Post #: 7
RE: Hull Force tunnel hull - 7/22/2008 9:17:52 PM
mr. ilikehelp
Status: offline
so what thicness ply is all that like 3/32 in. or what
       Post #: 8
RE: Hull Force tunnel hull - 7/23/2008 1:26:18 PM
mjderstine
Status: offline
most of the thickness is 1/8th hoby ply. the top is mostly 1/16th hoby ply. and the motor mount is constructed from 1/4" hoby ply. all of it is birch ply wood.
(in reply to mr. ilikehelp)
       Post #: 9
RE: Hull Force tunnel hull - 7/23/2008 5:54:30 PM
mr. ilikehelp
Status: offline
sweet so it looks like you have a step hull and a tunnel hull combined thats smart so what are the thinckest and thinest parts to the boat
       Post #: 10
RE: Hull Force tunnel hull - 7/24/2008 4:25:45 PM
mjderstine
Status: offline
the boat is thinnest at the rear at one inch at the hull and 2.5 total height
it is thickest at point where the hull meets the outer sponson at the top level at about 3.5 inches. and 2 inches for the hull.
       Post #: 11
RE: Hull Force tunnel hull - 7/25/2008 2:48:09 PM
j.m.
Status: offline
get a new pipe. something like this should do.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXZ563&P=7
This will DRASTICALLY improve the power that the engine makes. Allowing you to run a higher pitch prop, thus more top speed.
you'll need this, too:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXCB37&P=7
I think that'll fit your engine, but i'm not sure.
!Signature your in it put, this read to time the took you If
If the World didn''t suck, then we would just fall off.
       Post #: 12
RE: Hull Force tunnel hull - 7/29/2008 4:04:53 PM
mjderstine
Status: offline
J.M.
thanks for the info on the tuned pipes. i am going to stick with the stock muffler for now. and if i feel the need for the added power, i will go for it.
what would be a good prop recommendation for optimum RPm'S?
< Message edited by mjderstine -- 7/29/2008 4:05:07 PM >
(in reply to j.m.)
       Post #: 13
RE: Hull Force tunnel hull - 7/30/2008 3:08:50 AM
mr. ilikehelp
Status: offline
i noticed in the pics how you were running your servo and was wondering where to get that kind of push rod setup stuff.
       Post #: 14
RE: Hull Force tunnel hull - 7/30/2008 3:34:13 AM
j.m.
Status: offline
http://www3.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=gold+n+rod&search=Go
       Post #: 15
RE: Hull Force tunnel hull - 7/30/2008 5:02:16 PM
