which is better a prop or ducted fan?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Boats >> RC Airboats >> which is better a prop or ducted fan?
Page: [1]
Login
which is better a prop or ducted fan? - 7/6/2008 4:39:22 PM
kyosho501x
Status: offline
im working on a air boat and i need to find out if a prop or ducted fan will create the strongest thrust, im gonna be using a 540 motor(14t triple), if you can give me a link to the reconmended products, that would be great!
       Post #: 1
RE: which is better a prop or ducted fan? - 7/6/2008 10:51:12 PM
nitrosportsandrunner
Status: offline
most of the ducted fans iv looked at use brushless motors. iv too wondered if a ducted fan would be better for a airboat. i suppose size would be a factor. its not hard to get a 10'' prop on a 540 motor, but iv not seen any ducted fans that large.
_____________________________
VXL on 3s lipo, wheely king crawler, tt01 drifter
(in reply to kyosho501x)
       Post #: 2
RE: which is better a prop or ducted fan? - 7/6/2008 11:12:14 PM
kyosho501x
Status: offline
would a ducted fan even work since they pull? and what kv brushless motor should bring my boat to around 30mph or faster with 7.2v 6cell nimh?
(in reply to nitrosportsandrunner)
       Post #: 3
RE: which is better a prop or ducted fan? - 7/7/2008 2:27:16 AM
Status: offline
im using a puller prop on my electric boat right now: http://www.youtube.com/watch?v=FoDwDDKafwM
its a 20t motor and a 10X6 prop. i have a 10X8 prop coming in the mail soon, i hope that will increase the speed more. the real problem with using brushed motors it the runtime. with a 7.2v 3300mah battery i get just 4:30 runtime. a brushless motor and good lipo batt would increase runtimes alot.
       Post #: 4
RE: which is better a prop or ducted fan? - 7/7/2008 2:42:02 AM
kyosho501x
Status: offline
well im gonna get a ducted fan,but i dont know if the fan is too powerful cause it has 900grams of thrust so that should be more than enough
       Post #: 5
RE: which is better a prop or ducted fan? - 7/7/2008 2:34:43 PM
Status: offline
hey, i found a vid of a airboat using a ducted fan witha brushless motor. the ducted fan snaps off, but the fact that it moved so quickly on land should mean that it will go much faster in water. his boat it pretty small, so, you may want to make your simillar.
http://youtube.com/watch?v=g2Df_3Td_HQ
       Post #: 6
RE: which is better a prop or ducted fan? - 7/7/2008 3:56:57 PM
kyosho501x
Status: offline
oh yeah i saw that..............
       Post #: 7
RE: which is better a prop or ducted fan? - 7/7/2008 4:47:36 PM
mjderstine
Status: offline
that didnt last too long...
team HYPER MINIS
GB01 X 2, tb02, tb05, m03, clodbuster, twin force, raider
       Post #: 8
RE: which is better a prop or ducted fan? - 7/10/2008 4:48:49 PM
pinky_d_brain
Status: offline
im working on a duct fan air boat right now its taking a long time (not much time to wrok on it) but its coming along
I don't do normal
(in reply to mjderstine)
       Post #: 9
RE: which is better a prop or ducted fan? - 7/10/2008 5:22:44 PM
Status: offline
pinky, that boat looks great. id say it will be pretty fast, as the overall size is small and the battery/motor will have good power. looks like all you need is to wire things up and make a rudder/linkage and cover the top of the hull and your done.
(in reply to pinky_d_brain)
       Post #: 10
RE: which is better a prop or ducted fan? - 7/10/2008 6:13:00 PM
crispyspa
Status: offline
Pinky is da' man! All his boats look great and perform really well. ( I hope I didn't jinx it) *biting nails*
"Are you alright, son? I keep hearing the most terrifying sounds in there." (Foghorn Leghorn)
       Post #: 11
RE: which is better a prop or ducted fan? - 7/10/2008 6:17:24 PM
mr. ilikehelp
Status: offline
thats sweet some one should build with a twin ducted fan and giv epower to iether fan to turn
(in reply to crispyspa)
       Post #: 12
RE: which is better a prop or ducted fan? - 7/10/2008 6:20:27 PM
pinky_d_brain
Status: offline
Yup its a 3c lipo with a 4900kv motor be about 50,000 rpm with about 2lb of thrust efficient speed up to 200mph
Aiming for 1.5lb boat total when done all gear only ways about .5lb so I think it’s doable
O ya its only 10" long by 6" wide I cant what to see what happens
Duct Fans need a high rpm so if your motor is a low Kv I would go with a prop you will get more out of it
I don't do normal
       Post #: 13
RE: which is better a prop or ducted fan? - 7/11/2008 6:06:56 PM
mr. ilikehelp
Status: offline
wow thats a small boat with lots of thrust should run great. if you put so0me wings on it could be a plane for that size of a hull.
is the hull 100% balsa?
       Post #: 14
RE: which is better a prop or ducted fan? - 7/11/2008 6:42:29 PM
pinky_d_brain
Status: offline
Yes it is all balsa I will be installing a ply transom and covering inside and out with epoxy
I don't do normal
(in reply to mr. ilikehelp)
