Convert a HS225BB to HS 225MG?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Convert a HS225BB to HS 225MG?
Page: [1]
Login
Convert a HS225BB to HS 225MG? - 7/6/2008 9:55:15 PM
N1EDM
Status: offline
I need to replace some gears in one of my HS-225BB servos.
Can I replace the nylon gear set with Hitec metal gears, p/n 56396, essentially making it into a MG servo, or is there more to it than that?
Bob
_____________________________
An expert is someone who has been doing it for 15 minutes longer than you.
       Post #: 1
RE: Convert a HS225BB to HS 225MG? - 7/7/2008 2:41:01 AM
A.T.
Status: offline
quote:
ORIGINAL: N1EDM I need to replace some gears in one of my HS-225BB servos.
Can I replace the nylon gear set with Hitec metal gears, p/n 56396, essentially making it into a MG servo, or is there more to it than that? Thanks, Bob
Direct replacement:
HS-205BB/205MG/225BB Metal Gear Set = #56396
or new number
HS-225/5245 Metal Gear set = #55018
Servo Manual - DIY Gear Change
HS-225BB Specification sheet
HS-225MG Specification sheet
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
(in reply to N1EDM)
       Post #: 2
RE: Convert a HS225BB to HS 225MG? - 7/7/2008 3:55:47 AM
XJet
Status: offline
Not worth it IMHO Bob. The tiny plastic gear which is driven by the motor-cog is common to both the nylon and MG version and that's the one that breaks every time if you have a knock or excessive loading. So what's the point in having a metal gear set if the one gear that is always going to break is still nylon and will always fail first anyway?
When I'm not here, I'm at RCModelReviews
(in reply to A.T.)
       Post #: 3
RE: Convert a HS225BB to HS 225MG? - 7/7/2008 9:18:54 PM
MikeMayberry
Status: offline
The HS-225MG now uses a hybrid Karbonite/Brass first gear that is much stronger than the origional nylon first gears. Note that this gear cannot be metal due to RF noise created by the motor. If you look at most of the manufacturers metal geared servos you will see that most have a nylon first gear in all their servos.
Mike.
Click to see fullsize image.
Click for fullsize
Hitec RCD Rep
http://www.hitecrcd.com
(in reply to XJet)
       Post #: 4
RE: Convert a HS225BB to HS 225MG? - 7/8/2008 12:04:47 AM
N1EDM
Status: offline
OK thanks for the reply XJet, Mike, and A.T.
I presume that the 55018 series is the metal gear set that has the Karbonite gear in it?
Thanks a lot,
Bob
(in reply to MikeMayberry)
       Post #: 5
RE: Convert a HS225BB to HS 225MG? - 7/8/2008 8:04:11 PM
MikeMayberry
Status: offline
The metal gear set is Part# 56396
Mike.
Hitec RCD Rep
(in reply to N1EDM)
       Post #: 6
RE: Convert a HS225BB to HS 225MG? - 7/12/2008 11:36:53 PM
N1EDM
Status: offline
Thanks!
Bob
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU1
