funflier
CA, USA Status: online
I noticed that also that the Dynam ESC runs my battries down too far also. Have to watch the power drop off a little more closely/ I dont have any problem with heat with the hard timing set at I believe its the 2nd postion, I run a 3900 motor and 15c batteries, NOTHING even gets more warm (actually the motor is cool to the touch. Might have a tight pinion or belt too tight if your motor is getting hot. Batteries get only warm same with the esc.
_____________________________
King ll, 3900 w/10t pin, cnc head, custom cnc/trex tail, 43t + upgrade, Telebee gyro, Dx6i w/6100e RX, HS-65 servos. etc.
