B206 for the Mini Titan E325
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Scale RC Helicopters >> B206 for the Mini Titan E325
Page: [1]
Login
B206 for the Mini Titan E325 - 7/7/2008 5:25:44 AM
blade_killer
Status: offline
does anyone know of any non plastic Bell 206 fuselage that fits the E325, I understand it's too big to fit in most 450 size bodies....
_____________________________
Scott
       Post #: 1
RE: B206 for the Mini Titan E325 - 7/7/2008 6:20:13 AM
rotorsport
Status: offline
Try this one.
Charles
http://www.helidirect.com/product_info.php?cPath=59_508&products_id=6912
Instructions:
*HeliArtist J Ranger Pre-Painted fuselage use for
T-REX450X/XL/SEV2/TitanE325/Belt-CP
Specification:
*Body length:720mm
*Body width:230mm
*Body high:155mm
*Weight :205g
Accessory:
*Fiber Glass scale fuselage x 1
*Pellucid canopy cover x 2
*Horizontal stabilizer x 2
*Landing Gear Set x 1
*Manual x 1
< Message edited by rotorsport -- 7/7/2008 6:21:27 AM >
Charles
IAFF 2130
(in reply to blade_killer)
       Post #: 2
RE: B206 for the Mini Titan E325 - 7/7/2008 6:32:28 AM
blade_killer
Status: offline
rotorsport, thanks for that, but the HeliArtist b206 looks pretty low quality, not very detailed at all.
Scott
(in reply to rotorsport)
       Post #: 3
RE: B206 for the Mini Titan E325 - 7/7/2008 6:33:41 AM
rotorsport
Status: offline
If I see anything else I'll drop a line.
Have you checked with this one?
http://darthdrk.4t.com/photo3_1.html
< Message edited by rotorsport -- 7/7/2008 6:35:18 AM >
Charles
IAFF 2130
       Post #: 4
RE: B206 for the Mini Titan E325 - 7/7/2008 6:37:21 AM
blade_killer
Status: offline
yes, darth makes nice shells but I dont want plastic, looking for something sturdier. I've been looking on google for days and I just cant fine one that looks as nice as the Esky king2 b206 in the size I need for the mini t. They make a B206 for the Belt CP but I was told since the Mini T is bigger then the standard 450 it wont fit in that fuse.
< Message edited by blade_killer -- 7/7/2008 6:39:06 AM >
Scott
       Post #: 5
RE: B206 for the Mini Titan E325 - 7/7/2008 6:43:36 AM
rotorsport
Status: offline
http://www.helihobby.com/html/scale_helicopter.html
Charles
IAFF 2130
       Post #: 6
RE: B206 for the Mini Titan E325 - 7/7/2008 7:46:19 AM
blade_killer
Status: offline
I'm looking for something in the quality of this, notice the tail cone and details
Scott
       Post #: 7
RE: B206 for the Mini Titan E325 - 7/9/2008 12:55:55 AM
blade_killer
Status: offline
bump
Scott
       Post #: 8
RE: B206 for the Mini Titan E325 - 7/26/2008 2:14:59 AM
bkpilot
Status: offline
WOW...me too..let me know if you find something like that...
I don't think "THAT" was supposed to happen!!??
       Post #: 9
RE: B206 for the Mini Titan E325 - 8/4/2008 9:47:21 PM
blade_killer
Status: offline
well, I havent found a good B206 for the mini T so I dont know, I guess if we want one we'll have to have one made or make it our self.....
Scott
(in reply to bkpilot)
       Post #: 10
RE: B206 for the Mini Titan E325 - 8/7/2008 3:34:25 PM
CarFreak92
Status: offline
if im not mistaken the esky bell 206b fuselage fits the belt cp which is pretty much the same size as the titan therefore you porbably could fit the mini titan into the esky fuselage
T-MAXX 2.5 with 3.3, motorsaver airfilter, robinsons racing brake kit, traxxas wheelie bar and RPM skid/wear plates
       Post #: 11
RE: B206 for the Mini Titan E325 - 8/7/2008 5:25:49 PM
darthdrk
Status: offline
Esky makes a 206 for the King2 I dont think they make one for the Belt Cp which is a 450 size heli. The Mini T is a 450 size heli
Owner/OEO/Mastercraftsman of Darth's
Helibodies Darthdrk@juno.com
(in reply to CarFreak92)
       Post #: 12
RE: B206 for the Mini Titan E325 - 8/12/2008 6:11:56 AM
blade_killer
Status: offline
Darth, they make one for both the King and the Belt cp, the problem is the MT is bigger then the belt CP so I dont know if it would fit in that fuse, the part number is EK4-0059, the king2 bell 206 is EK4-0051
< Message edited by blade_killer -- 8/12/2008 6:13:44 AM >
Scott
(in reply to darthdrk)
       Post #: 13
RE: B206 for the Mini Titan E325 - 8/15/2008 7:15:38 AM
darthdrk
Status: offline
Yep youre right, I came across one today. 120.00 from BPHobbies. The critical distance is from the mainshaft to the tailrotor shaft. If these are relatively close to the Belt Cp you chould be OK What I mean about close is within an inch. You can do a little shifting of the mechanics to get it to sit right .
       Post #: 14
RE: B206 for the Mini Titan E325 - 8/15/2008 6:02:20 PM
Druss
Status: offline
I think the bigger issue is the way the servos are placed on the E325? They are placed to make it easy to install and maintain but makes it wider than most 450s.
       Post #: 15
