knobby1
Joined: 10/17/2007 From: Sydney, , AUSTRALIA Status: offline
Hey Mav, Check to make sure the little gas restrictor just downstream of the gas filter in the yellow gas tube isn't blocked, they're very tiny and doesn't take much for them to block up, let us know how you get on. The Falcon should light up nicely with a gas % of ~45-55% if it's a cold day you may have to increase this a bit to get a nice EGT temp increase due to the pressure drop in your gas can, experiment a little at a time. The Falcon should be "on the pump" by the end of the second start cycle. Eric is traveling at the moment so it may take a day or two for him to reply. Cheers, Smithy.
_____________________________
Brett Smith AusJets.com.....Jet Central turbine engines, Jet-Joe engine service.
