What is the part number for the most updated needle valve for a 91FX
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> O.S. Engines Support >> What is the part number for the most updated needle valve for a 91FX
Page: [1]
Login
What is the part number for the most updated needle val... - 7/7/2008 3:19:47 PM
wjbender
Status: offline
Bill Baxter , I have an OS 91FX that exhibits all the problems detailed here in great length related to the needle valve assembly cast as part of the rear engine cover. Here is a picture of what I believe is the updated version that helps fix the problem.
I asked my LHS to order a new cover and needle assembly, but it still had the needle valve holder cast as part of the cover???? The new one has a composit needle valve assembly attached with a steel bracket that screws to the back cover or can be mounted to the firewall. I am willing to give this engine one more chance to live if I can get the correct part.
As a reference, here is the part I ordered based on this response from you in an earlier posting, but this part looks the same as what I have although it did have the composit needle valve holder, but still cast as one with the back cover.
If you have the old needle assembly, changing the o-rings won't cure the problem. The needle can have problems being heated by the engine, which causes fuel vapor bubbles in the fuel line. These make the engine go lean. A full conversion is:
OSMG4147 29507000 COVER PLATE ASSY 91FX US$40.99
This includes everything you need to convert the engine to the new needle assembly...rear cover, needle mount, and needle valve assembly.
Bill Baxter, Manager Hobby Services/Futaba Service/North America
3002 N. Apollo Dr. Ste. 1 Champaign, IL 61822 USA
Thanks Bill Bender
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: What is the part number for the most updated needl... - 7/7/2008 7:22:34 PM
Bax
Status: offline
How old was that prior posting? The one you got was a first revision.
Here's what you need for the current version:
OSMG6997 26582900 VALVE ASSY 40-65LA US$21.99
OSMG7152 26582931 NEEDLE STAY 91FX 65LA US$3.49
OSMG4078 29057000 COVER PLATE 91SX-H US$16.99
These parts can be ordered through any hobby retailer who sells O.S. Max engines and accessories.
_____________________________
Service Phone: 217 398-0007
Email: hobbyservices@hobbico.com
(in reply to wjbender)
       Post #: 2
RE: What is the part number for the most updated needl... - 7/7/2008 7:47:41 PM
wjbender
Status: offline
Thanks Bill,
Is the version shown in my photo the correct version? What is different? I hate to have the LHS order the worng thing again.
(in reply to Bax)
       Post #: 3
RE: What is the part number for the most updated needl... - 7/10/2008 3:47:39 PM
Bax
Status: offline
Your picture shows the current version needle installation.
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
3.438RCU1
