caribefoto
FL, USA Status: offline
Typically, 75% of lift (thrust) of a prop is generated by the outermost 25% of blade length, so the prop doesn't have to be that much larger in diameter than the cowl. Depending on prop speed (RPM), pitch and other variables, an even greater percentage of lift may be generated by the outer 25%............John
_____________________________
Well, if crime fighters fight crime and fire fighters fight fire, what do freedom fighters fight?
