RE: Boomerang Sprint Build Thread!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
AMT Netherlands Pegasus HP - RTF
Seller:  thunderbolt-RCU
Details:   $3,000.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> RC Jets >> RE: Boomerang Sprint Build Thread!
Page: <<   < prev  22 23 [24] 25 26 27 28 29 30 31   next >   >>
Login
RE: Boomerang Sprint Build Thread! - 4/2/2009 8:56 PM
ricardinho
Score: 100
Last Login: 3/26/2013
Status: offline
they are very nice gear and look the best. little pricey but worth it.. and you can get any part you need later on. they stock them all...
Hide Signatures
(in reply to R/C Gypsy)
       Post #: 576
RE: Boomerang Sprint Build Thread! - 4/3/2009 12:43 AM
killerG
Score: 100
Last Login: 5/19/2013
Status: offline
Ya, I have decided to use the gear set from Dreamworks.
_____________________________
Graham
Hide Signatures
       Post #: 577
RE: Boomerang Sprint Build Thread! - 4/6/2009 9:05 PM
ricardinho
Score: 100
Status: offline
hello dave did the p 80 fit with no modification. just curious.. was buying a p70 but may decide to get the p80 instead.... thanks pat
Hide Signatures
(in reply to Dave03B)
       Post #: 578
RE: Boomerang Sprint Build Thread! - 4/6/2009 10:10 PM
Dave03B
Score: 100
Last Login: 5/4/2013
Status: offline
Yes, straight in. It's designed with the p80 in mind.
Dave Bright - http://www.wimbornemac.org
Hide Signatures
(in reply to ricardinho)
       Post #: 579
RE: Boomerang Sprint Build Thread! - 4/6/2009 10:22 PM
ricardinho
Score: 100
Status: offline
hello dave great to know this. i have a p70 mount in it right now. will the p 80 mount be the same as the p70 mount . i would like to use the same holes ..pat
Hide Signatures
       Post #: 580
RE: Boomerang Sprint Build Thread! - 4/6/2009 10:46 PM
KC36330
Score: 328
Status: offline
quote:
ORIGINAL: ricardinho
...........i have a p70 mount in it right now. will the p 80 mount be the same as the p70 mount . i would like to use the same holes ..pat
No.
JetCat USA Rep / KingTech Turbines Rep
Hide Signatures
       Post #: 581
RE: Boomerang Sprint Build Thread! - 4/7/2009 8:45 AM
Doc...
Score: 100
Last Login: 4/1/2012
Status: offline
Hi,
You may want to read post 404 in this thread. It was also mentioned in some earlier threads about the clearence being to tight without the modifacation. Using the P-80 mount, I added the 3/8" hardwood spacer on both sides and it is perfectly centered. I did do a trial fit before the final install. I used 30 min. epoxy instead of CA for a stronger support. Also, be sure to apply BVM Heat Shield back there both in the fuse and the turdle deck. Weight is not an issue.
Doc...
"Never give up, Life is to short"
Hide Signatures
       Post #: 582
RE: Boomerang Sprint Build Thread! - 4/7/2009 3:42 PM
Mace
Score: 100
Last Login: 3/4/2011
Status: offline
Without looking at my P-80 installation, isn't the P-80 mount offset. Can it be rotated 180 degrees to give a centered fit? Mine seems as if centered with out the additional hardwood rails. I may also have a different P-80 mount than others. The Boomerang seems a few pounds heavier than my Shockjet taking into consideration the Shockjet has a P-60 and half the fuel capacity. What are most of you guys having to do with CG on the Boomerang? Are you having to move batteries or add weight to get it on or near the CG? I cut up BVM insulation and installed, added aluminum tape over that and then painted the inside of the turtle deck with heat shield to manage the heat from the business end of the P-80. The combination of all three will do the job to keep the turtle deck cool.
MACE
Peace Is That Brief Glorious Moment In History When Everybody Stands Around... Reloading
Hide Signatures
(in reply to Doc...)
       Post #: 583
RE: Boomerang Sprint Build Thread! - 4/7/2009 3:57 PM
KC36330
Score: 328
Status: offline
quote:
ORIGINAL: Mace
...............isn't the P-80 mount offset. Can it be rotated 180 degrees to give a centered fit?
all the JetCat mounts are offset and require the 3/8" shim, flipping the mount will only offset the turbine 3/8" high rather then low.
Hide Signatures
(in reply to Mace)
       Post #: 584
RE: Boomerang Sprint Build Thread! - 4/12/2009 2:08 PM
Dave03B
Score: 100
Status: offline
Hi Guys,
Anyone using crow on the Sprint? I messed about with it yesterday and found that with 60%mix reflex and full 90degree is like hitting a wall. Needed half power to stop it from falling. Reduced reflex to 30% and full landing flap to about 75degree and had a much more predictable landing approach with around 1/3rd throttle. I don't think this design needs crow with that flap, but it's good to be able to come in on power so if it's needed, the throttle is more lively to go round again.
At our field we've decided the CG is very safe (nose heavy) as per manual, Inverted flight needs a lot of down elevator. I've moved my turbine to the back of the mounting rails, and will now move receiver packs aft too.
Be interested to hear other users thoughts.
Click to see fullsize image.
Click for fullsize
< Message edited by Dave03B -- 4/14/2009 2:10 PM >
Hide Signatures
       Post #: 585
RE: Boomerang Sprint Build Thread! - 4/12/2009 3:15 PM
ricardinho
Score: 100
Status: offline
hello dave i have the full flap with crow on my sprint. i wont land it without it . its nice because you can come in with good power on so its already spooled . always remember though not to come in with the nose up with crow. the sink rate is considerable. i carry about a quarter throttle with the nose down slightly. keeps the airspeed perfect. i have two settings for flaps. one normal rate with no crow and full flap with crow. as i said before though you will need to mix down elevator for the full flap with crow. on a few posts back i show my plane with the full crow position. i was reading post on here some people were saying you dont need flaps . i dont agree. with the full flap crow you can come in very slow keeping your ground speed to a minimum for roll out. means less brakes... glad to see someone else using crow... pat
Hide Signatures
       Post #: 586
RE: Boomerang Sprint Build Thread! - 4/12/2009 8:08 PM
Doc...
Score: 100
Status: offline
Hi,
I feel using the flaps is a good thing because of using power durning landing. Some posts back said the mix 30% down elev with the flaps. I understand that because once the flaps are deployed, without the mix, the nose wants to go up. So, could you explain crow. I'm due for my maiden in about 2 weeks.
Doc...
Hide Signatures
       Post #: 587
RE: Boomerang Sprint Build Thread! - 4/13/2009 1:55 AM
ricardinho
Score: 100
Status: offline
hello doc. i dont know the exact settings for it. i bought the plane from my friend and we just did a data transfer on my 9303 2.4. ok maybe this will help. i have two rates for flaps . on the first rate the flap will come down about 45% with a slight bit of down elevator . you will have to play with it until the plane doesnt ballon anymore. when i go to full flap is when the crow is activated. the elevator will go down a little further along with about a quarter inch of up ailerons.. i only go for the full flap with crow when i land. i dont mess with the low rate flap. soon as i turn on the down wind i level the plane and go full flap. the plane becomes a big **** cat. very stable. no ballooning at all. just keep your throttle up a little as you turn on base with the nose slightly down. the plane will come down like its in slow motion. unreal how stable. you will like it . you dont need a long roll out. just play with the mixes until you get the elevator set right.. hope this helps.. pat
Hide Signatures
       Post #: 588
RE: Boomerang Sprint Build Thread! - 4/13/2009 10:01 AM
Doc...
Score: 100
Status: offline
Hi Pat,
OK. I didn't know about the ailreons. Your right. I will have to play around with it. Thanks,
Doc...
Hide Signatures
       Post #: 589
RE: Boomerang Sprint Build Thread! - 4/14/2009 1:54 AM
iiievolution
Score: 100
Last Login: 5/17/2013
Status: offline
Hello
Yes pitch changes slightly on mine too but with variations in airspeed, not thrust. Mine is also set up as per the manual CG but for inverted I only need a touch of down.
Paul
P.S. Managed 325 km\h yesterday
Dont talk to me about props. I dont care I dont want to know!!!
Hide Signatures
       Post #: 590
RE: Boomerang Sprint Build Thread! - 4/14/2009 1:09 PM
Propellars
Score: 100
Last Login: 4/20/2013
Status: offline
Hi all
My Sprint is mounted with an oversize turbine (15 kg, 33lbs), and I think I need to turn it down a bit, in order not to destroy the jet. What is the largest thrust-sizes that you fly with?? Is 12 kg (27lbs) still to much?
How does your Sprint’s perform in a side-wind landing? Are you just applying sufficient ruder, to make it fly straight, or how?
Flying greetings, Lars R "Slow Builder"
Hide Signatures
(in reply to iiievolution)
       Post #: 591
RE: Boomerang Sprint Build Thread! - 4/14/2009 2:05 PM
Dave03B
Score: 100
Status: offline
Pretty sure max for this aiframe is p80 sized, so around 20lbs. I flew in a 10mph cross wind yesterday and the sprint was unaffected. The wind did swing around more for my final flight, but a touch of the big rudders kept it straight.
I've also sorted my crow. Full landing flap is around 70degrees with approx 5degrees reflex. Landing flap needs a small down elev mix, comes in on 1/3rd power. Once I'm over our fence line, cut the power and she comes in nicely. Each flight i'm moving my CG back, but am really starting to enjoy flying it now.
Thanks to JonT for photos....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Dave03B -- 4/14/2009 2:12 PM >
Hide Signatures
(in reply to Propellars)
       Post #: 592
RE: Boomerang Sprint Build Thread! - 4/14/2009 3:28 PM
iiievolution
Score: 100
Status: offline
I flew mine in a very strong crosswind, the sprint is not very much affected by it. I dont use rudder, I just come in at a crab angle and just before touchdown I de-crab it with the rudder. Thats how we do it in full size.
Paul
Hide Signatures
       Post #: 593
RE: Boomerang Sprint Build Thread! - 4/14/2009 3:44 PM
ricardinho
Score: 100
Status: offline
i havent had a strong crosswind yet with my sprint but the way you explained is the way i always flew my giant areobatic planes.
Hide Signatures
       Post #: 594
RE: Boomerang Sprint Build Thread! - 4/14/2009 3:51 PM
ricardinho
Score: 100
Status: offline
paul sorry about bringing up prop planes. i see you dont want to here about them hahaha.. i feel the same about them also..take care
Hide Signatures
       Post #: 595
RE: Boomerang Sprint Build Thread! - 4/14/2009 4:19 PM
iiievolution
Score: 100
Status: offline
Props
Hide Signatures
       Post #: 596
RE: Boomerang Sprint Build Thread! - 4/14/2009 4:24 PM
Doc...
Score: 100
Status: offline
Whats a prop??????????????????????
Hide Signatures
       Post #: 597
RE: Boomerang Sprint Build Thread! - 4/14/2009 4:28 PM
ricardinho
Score: 100
Status: offline
props are for boats!!!!!!
Hide Signatures
       Post #: 598
RE: Boomerang Sprint Build Thread! - 4/14/2009 6:15 PM
ltdorn1
Score: 100
Last Login: 4/6/2013
Status: offline
Holy crap...33lbs!
I have a falcon in mine 21-22lbs or so... and i can go from lift off to straight vertical (full fuel) with my falcon...
Make sure you post pictures when you rip your wings off..lol i have never seen a boomer blow apart in the air, but 33lbs should do it.
OR..... sell your sprint and put that big monster in a Boomer XL...
I personally think the falcon (21# or so) is the perfect match for the Sprint.
Lawrence
LT Dorn-Boomer Sprint - Artes Falcon
Innovation, creativity and hard work makes us progress!
Hide Signatures
       Post #: 599
RE: Boomerang Sprint Build Thread! - 4/15/2009 12:53 AM
Propellars
Score: 100
Status: offline
Thanks for your reply's concerning thrust and croswind
Hide Signatures
(in reply to ltdorn1)
       Post #: 600
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.203RCU1
