RE: Boomerang Sprint Build Thread!
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> RE: Boomerang Sprint Build Thread!
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Boomerang Sprint Build Thread! - 7/18/2008 6:36 AM
highhorse
Score: 100
Last Login: 3/21/2010
Status: online
quote:
ORIGINAL: starzak
Terribly dark pictures. Cantcha brighten them up some with your photo processor ?
Thanks.
... zak
Hmmmmmm. Check your monitor?
The pics are a SMALL bit underexposed but perfectly clear and usable IMO
_____________________________
RCU Rocks, I''d hate to be without it !!
Hide Signatures
(in reply to Ed)
       Post #: 51
RE: Boomerang Sprint Build Thread! - 7/18/2008 7:20 AM
digitech
Score: 100
Status: offline
quote:
ORIGINAL: volkan
A bit more done today, the gear is surprisingly easy to install! Only think to mention is that you will need countersunk screws in order for the top CF plate to fit... right sandor?
Also got the fuel tank today, which slips right into the fuz, absolutely perfect fit!
you did?
i thought there was sufficient space for those.
will fix that anyway
Sandor Kruise
Dealers for:JetCat,Graupner,Emcotec,Skymaster,Pro-Lynx,Airpower,Jet-1A,Composite-ARF,Behotec.
"Home of the Pro-Lynx Gears"
Hide Signatures
(in reply to volkan)
       Post #: 52
RE: Boomerang Sprint Build Thread! - 7/18/2008 8:35 AM
digitech
Score: 100
Status: offline
if anyone has a question about using spacers?
i was reading this:
Quote"best to manufacture a nose strut specific for the Sprint to eliminate any need for spacer blocks and to get the stance correct."
1 .well there is no room , the retract is as far forward as possible , the wheel touches allready the servo bay therfore you must get a offset.
that is why we supply for free the "raisers"..
2 .steering rods , there is not sufficient place to use the steering rod to collapse all the way down.
3. boomerangs Hate to take off in a negative angle of attack , i flew all of them.
4 . we designed it so that both the front and the main oleo,s can be swapped for even the 40LBS oleo,s.
wich for the USA market (Smoke tank-1 gallon fuel - P120se-titan) will like.
our special made Kingcat oleo,s will fit the Sprint also .
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by digitech -- 7/18/2008 10:06 AM >
Sandor Kruise
Hide Signatures
(in reply to digitech)
       Post #: 53
RE: Boomerang Sprint Build Thread! - 7/18/2008 11:12 AM
Big feet
Score: 100
Status: offline
Hi buckerboy,
My club mate found these people that make sheets that you put into your printer (either get the inkjet or laser ones to suit your printer), then make your own decals.
he has used this and made some nice decals of our club badge.
Hope this helps.
http://www.craftycomputerpaper.co.uk/ProductDetail.asp?ProductID=158&CatID=15
Please remember, RC is dangerous to your wealth
Hide Signatures
(in reply to buckerboy)
       Post #: 54
RE: Boomerang Sprint Build Thread! - 7/18/2008 11:14 AM
Turbinac
Score: 104
Status: offline
Yes, that is our same 125 ounce (3.7 Litres) custom made Sullivan fuel tank as used in the Sprint, the Elan and also fits the XL with a tiny modification to a former.
Gives you the option to have any flight time from 5 minutes up to over 15 minutes. Just fill to the level you want.
Alan.
Alan Cardash,
Boomerang Jets Ltd./Boomerang Jets USA Llc.
Hide Signatures
(in reply to BCoston)
       Post #: 55
RE: Boomerang Sprint Build Thread! - 7/18/2008 12:16 PM
Undecided
Score: 100
Last Login: 3/20/2010
Status: offline
Hello Alan
Any chance you will sell the sprint in a kit version for those of us who like to build. I get a lot of enjoyment from building and would love to build one from a kit and since it’s a balsa and ply plane with a little bit of fiberglass seems it would lend itself to kit form rather easily but I don’t know the logistics or costs associated in gathering all the pcs together and putting it in a kit. I plan on purchasing a arf from Patricia some time in the near future but I sure would like a kit version also. Food for thought.
Thanks, Neal
Hide Signatures
(in reply to Turbinac)
       Post #: 56
RE: Boomerang Sprint Build Thread! - 7/18/2008 1:12 PM
Turbinac
Score: 104
Status: offline
Sorry, Neal, no chance of that happening.
Alan Cardash,
Hide Signatures
(in reply to Undecided)
       Post #: 57
RE: Boomerang Sprint Build Thread! - 7/21/2008 11:36 PM
volkan
Score: 105
Last Login: 6/29/2009
Status: offline
Done a bit more in the past few days. The MASSIVE intakes are in and the model is now on its wheels. Just waiting for some bits and pieces to finally finish of the model. Fitting the retracts were quite easy, no major modification required.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Volkan D.
Al''s Hobbies Jet Centre IT - www.alshobbies.com
Hide Signatures
       Post #: 58
RE: Boomerang Sprint Build Thread! - 7/23/2008 12:18 AM
volkan
Score: 105
Status: offline
Almost done!
Few more pictures of the final install, hope to have the model put together tomorrow. After that its just the radio and linkage setup.
Click for fullsize
Click for fullsize
Click for fullsize
Volkan D.
Hide Signatures
       Post #: 59
RE: Boomerang Sprint Build Thread! - 7/23/2008 2:41 AM
GreenAcre
Score: 105
Status: offline
Isn't the Sprint about the same as the Boomer Intro??
Hide Signatures
       Post #: 60
RE: Boomerang Sprint Build Thread! - 7/23/2008 5:20 AM
BuschBarber
Score: 100
Status: offline
It lis bigger is some areas.
Rich
byronf16@gmail.com
Hide Signatures
(in reply to GreenAcre)
       Post #: 61
RE: Boomerang Sprint Build Thread! - 7/23/2008 12:11 PM
Undecided
Score: 100
Status: offline
What is the max wheel size diameter the wheel wells will take for the main wheels? On the digitech nose wheel strut what is the max wheel diameter usable on it.
Thanks, Neal
Hide Signatures
(in reply to BuschBarber)
       Post #: 62
RE: Boomerang Sprint Build Thread! - 7/23/2008 12:16 PM
digitech
Score: 100
Status: offline
quote:
ORIGINAL: Undecided
Thanks, Neal
76mm
Nose wheel strut on the standard oleo 63mm (you can inflate the original tyre from 57 to 63mm)
on "the luxe" front oleo (optional) you can use a 76mm tyre.
BUT it wont fit the wheel well , ideal would be 63 front and 74 on the mains
i promisse you one can take of from a potato field...
Sandor Kruise
Hide Signatures
       Post #: 63
RE: Boomerang Sprint Build Thread! - 7/23/2008 3:04 PM
BuschBarber
Score: 100
Status: offline
What are the lengths of the Main Gear Struts and the Nosewheel Strut?
Rich
byronf16@gmail.com
Hide Signatures
       Post #: 64
RE: Boomerang Sprint Build Thread! - 7/25/2008 1:03 PM
buckerboy
Score: 100
Last Login: 3/15/2010
Status: offline
Hi Big Feet,
many thanks for the help regarding the decals, managed to end up getting them from a company called "Pyramid Models" in the UK, they have a great selection of decals, so now sorted thanks.
Hey Volkan, sorry for hijacking your thread, but the Sprint is looking great, I'm looking forward to seeing it in the air at one of the shows, thanks for an interesting thread.
Regards,
Vince.
one day I''ll actually go flying!
Hide Signatures
       Post #: 65
RE: Boomerang Sprint Build Thread! - 7/25/2008 2:36 PM
lov2flyrc
Score: 104
Status: offline
quote:
ORIGINAL: digitech
i was reading this:
At this moment, I will leave this to the designer to explain. Will follow up with installed pictures early next week.
There is room to do it right!
Todd
Owner/President: Dreamworks Model Products LLC
www.dreamworksrc.com 386-852-4793
Hide Signatures
       Post #: 66
RE: Boomerang Sprint Build Thread! - 7/25/2008 3:24 PM
digitech
Score: 100
Status: offline
quote:
ORIGINAL: lov2flyrc
quote:
ORIGINAL: digitech
i was reading this:
Todd
mm we got it right?
Sandor Kruise
Hide Signatures
(in reply to lov2flyrc)
       Post #: 67
RE: Boomerang Sprint Build Thread! - 7/25/2008 7:31 PM
highhorse
Score: 100
Status: online
Popcorn please.....
And I'm not betting against Todd !
Hide Signatures
       Post #: 68
RE: Boomerang Sprint Build Thread! - 7/26/2008 3:50 AM
Woketman
Score: 100
Status: offline
I'll bet WITH Todd!!! (cause I know I'll win that way)
Hide Signatures
(in reply to highhorse)
       Post #: 69
RE: Boomerang Sprint Build Thread! - 7/27/2008 9:40 PM
larryfl1
Score: 100
Last Login: 2/20/2010
Status: offline
what is the approximate time for a somewhat layman to get this bird together and ready to fly?
Hide Signatures
(in reply to Woketman)
       Post #: 70
RE: Boomerang Sprint Build Thread! - 7/28/2008 7:11 AM
digitech
Score: 100
Status: offline
quote:
ORIGINAL: larryfl1
10 hours max
Sandor Kruise
Hide Signatures
(in reply to larryfl1)
       Post #: 71
RE: Boomerang Sprint Build Thread! - 7/28/2008 7:32 AM
Turbinac
Score: 104
Status: offline
quote:
ORIGINAL: larryfl1
I think Sandor must work superfast.
The airframe is quick, probably 10 hours, but the installation of radio, turbine and retracts, etc. should be done at your own pace, with care, to avoid later problems and re-fitting.
For a moderate builder, allow another 10 hours or more for that side of the build.
I certainly couldn't get one out of the box and be ready to fly in 10 hours and I designed it!! One days build?????
In any case, the build is part of the experience of modelling. It is enjoyable in it's own right.
So enjoy it!!
Alan.
Alan Cardash,
Hide Signatures
       Post #: 72
RE: Boomerang Sprint Build Thread! - 7/28/2008 8:18 AM
digitech
Score: 100
Status: offline
No i dont work Superfast.
i guess if you do it right at once , you dont need another 2 days to fix it.
it takes me 2 days at my office , wich i do all orders also on those 2 days.
the airframe incl servo,s is assembled in about 3 hours max.
retracts 2 hours max.
the rest is turbine installation.
most work is CG , Deflections , Programming
and making the system bubblefree and testing it.
Elan toulk me also same time...
most time is the delivery it takes to get something.
it takes me a cartidge of Hysol to stenghten some critical points and aluminium pins that fall out here and there.
reglue the Servotray and tank tray.
but they always fly ok...
as you know we test all our gears with your airframes , Before we start selling them.
Sandor Kruise
Hide Signatures
       Post #: 73
RE: Boomerang Sprint Build Thread! - 7/28/2008 2:21 PM
volkan
Score: 105
Status: offline
Hi Guys,
Back to the actual build, the model is almost 99% complete now! Just a few minors bits to do, and Alan picked it up earlier today.
I will be on holiday for a week, but I suspect Alan will be on here soon with pictures of the final model!
Volkan D.
Hide Signatures
       Post #: 74
RE: Boomerang Sprint Build Thread! - 7/28/2008 3:11 PM
digitech
Score: 100
Status: offline
quote:
ORIGINAL: volkan
Hi Guys,
Parts are send out
incl some Locktite.
Sandor Kruise
Hide Signatures
       Post #: 75
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.434RCU1
