one-syk
IL, USA Status: offline
find what? you should be able to cross refrence the part's to find out what part's they still use, or what part's are similar. im sure you can find shock's, wheel's and tires to get your rally build going...im just unsure of the A-arms. im thinking they used longer A-arms for the Super nitro RS4 rally....which would explain the huge wheels/tires and 300mm body's. for your 200mm rally build....i would try longer shock's and some larger wheel's with rally tires.....like someone above said...you may need to notch the 2.5mm chassis plate to allow the A-arms to travel down further than allowed for the on-road setup...but its not alot of notching...just where the pivot pin goes through the A-arm. you should be able to figure out somthing for fairly cheap, and with minimal work. its a hobby....you just gotta figure it out, and make it work sometimes.
< Message edited by one-syk -- 7/10/2008 3:19:45 AM >
_____________________________
2008 HPI Savage X 4.6, HPI pullstart...
