slawhammer -> RE: New to the 1/5 scale RC world (7/26/2008 2:59 PM)
Ok... As suggested by Ryan from DDM to change the piston ring...From the orig owner.. Stated it is a CY29CC engine...So is there a stamped number on the piston? How do you measure the piston ring?I have had the engine running and put 1 tank of fuel thru it ,,but seems too smoke quite a bit..Possiable bad piston ring..,,My carb setting are High Side 1 1/8 turn out same as for the low side..Carb is a Walbro 668..seems to bog down when given it a quick throttle responce...If you ease the throttle its seem to be some what smoother...Any suggestions? Thanks for your help...Roger
