slawhammer -> RE: New to the 1/5 scale RC world (8/13/2008 12:03 AM)
OK..David0666 called it in post #115..I check it out.Price was right...So now I got new BLING..SO from the looks of it I will have to get pin adapters. There is no band on the inside of hub...Here are so pictures...These are bigger than stock wheels and tires.....So question is where do I find these Pin adapters..These wheel are for FG..As far as I can tell the inside measures 17 mm Thanks for all your help..Roger EDIT: Looks like the pins are 11.5 mm Having hard time measuring for pins and inside hub,,,
