alan0899
Joined: 4/17/2006 From: Cundletown, NSW, AUSTRALIA Status: offline
G'day Mate, The fuel cannot run to the front of the tank in a dive, it is imposible, for that to happen, the fuel must accelerate faster than the plane, & that can't happen unless the plane stops in mid air then the fuel can fall forward. Also the clunk can't fall to the front of the tank in a dive, for the same reason. That is why it doesn't happen in any of your other planes, so you must have a hole in your fuel line, in the tank, or the clunk is getting stuck at the back of the tank, then as the nose drops, the clunk could come out of the fuel, because it is no longer level, & then it could suck air. Hold the plane nose straight up, & give it a shake, you should be able to hear the clunk swinging side to side, & top to bottom, if you can't then there is your problem.
_____________________________
Good Flyin Mate. Keep Thyne Airspeed up, lest the ground arise & smite thee, Allan.
