RE: HOW TO BREAK AN ENGINE IN!!!!!!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: HOW TO BREAK AN ENGINE IN!!!!!!
Page: <<   < prev  1 [2]
Login
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/11/2008 4:13:29 AM
st1_racer
Status: online
how do you know if the piston is dead in the center is it like that before u break it in
_____________________________
boogidy boogidy boogidy lets go racing boys
Thunder Tiger St1 is going to be sold/ Gs Racing Storm Cl-1. 1/8 Truggy kit
(in reply to madmax22)
       Post #: 26
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/13/2008 11:42:24 AM
j_blaze
Status: online
i still say the drake method is the best. half hour, no chance for fly aways or overdriving, no snapped con rods, no overheating or under heating. the only thing to worry about is the noise, wear ear plugs.
CASTER K8T Pro - GO 21 R-Spec/RB WS7III, JR, DX3R
Caster Zx1-R (soon) - ????
       Post #: 27
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/13/2008 3:17:17 PM
Force4x4
Status: offline
quote:
ORIGINAL: st1_racer
anyone help me
Take the glow plug out and watch the piston!
Jammin X1-CRT Pro .21 V-spec, Jammin X1 CR FTE Axe Mamba Rossi, Ofna Violator 9.5 Force .32, Kyosho Mega Force O.S. .18 CV-R
(in reply to st1_racer)
       Post #: 28
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/13/2008 4:12:39 PM
rebelracer246
Status: offline
quote:
ORIGINAL: st1_racer
anyone help me
what i do is i move the piston till it starts to get tight and then i go back the other way till the piston gets tight then i go by what i feel is the bottom
http://www.youtube.com/watch?v=B6nJCigwtps
       Post #: 29
RE: [Awaiting Approval] - 7/13/2008 4:47:48 PM
st1_racer
Status: online
ok so turn the flywheel before i break it in to see if its at the bottom?
(in reply to rebelracer246)
       Post #: 30
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/13/2008 5:11:31 PM
rebelracer246
Status: offline
not before after you run it when it cools you want to have it at bdc so the sleve will still have pinch
       Post #: 31
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/13/2008 8:27:59 PM
windowlicker
Status: offline
make a mark on the bottom of the flywheel with a marker pen so you know where bdc is. Then its much quicker to put it at BDC when you are finished running
Hellfire SS - GO .25 - DX3R - 5955TG - 5645MG - Speedtech Carbon
       Post #: 32
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/13/2008 8:46:58 PM
rebelracer246
Status: offline
the last time i did that the mark went away
(in reply to windowlicker)
       Post #: 33
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/13/2008 9:04:55 PM
windowlicker
Status: offline
try scratching it, I've done that with my Firestorm. use a screw driver and scratch a line
       Post #: 34
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/13/2008 9:12:45 PM
rebelracer246
Status: offline
i never thought about that lol
       Post #: 35
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/14/2008 2:51:15 AM
rebelracer246
Status: offline
quote:
ORIGINAL: madmax22
yes you do but you dont have to go as easy on it as when it was new.
will the repinching process work with a glass top stove?
       Post #: 36
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/16/2008 8:26:40 PM
McFly505
Status: offline
Sadly, that re-pinching process will not add any life to your engine.
It will however, result in an out of round sleeve with a tight spot or two, fooling you into believing that you have added 'pinch' back to the engine.
The piston and sleeve will wear quickly, leaving you with a dead mill.
BTDT.
I've tried every method of re-pinching an engine you can possibly think of and only one works.
Raya Racing
This is the same procedure that the factories use to 'pinch' a sleeve when they are made.
Scott
AE RC8-OS Speed, AE RC8-OS V Spec, AE RC8T-Coming soon!!!
       Post #: 37
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/21/2008 4:40:05 AM
madmax22
Status: offline
rebel if you want to still do it i think it would work just put it on HI and let it warm up for a little bit!
They call me "butthead".......
(in reply to McFly505)
       Post #: 38
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/21/2008 6:44:35 AM
phattracker
Status: offline
quote:
ORIGINAL: st1_racer
HOW DO YOU GET YOU PISTON DROP DEAD IN THE CENTER, AND HOW DO YOU KNOW. CAN SOMEONE HELP?
Without taking the head and button off to actually look. Roll the engine over by hand, feel the pinch yet? Now do it again. Now mentally draw a pic in your head of whats going on in the engine, up down up down. Just split the difference in between the pinch and the point of least resistance. The piston will go full stroke per turn of the flywheel so when you feel the least resistance, that is most likely gonna be close to BDC. Or just take the cooling head and button off and actually look. Mark the flywheel with a sharp knife or a screw driver or sumthin, on the top of the flywheel. This way when your done playin, roll the motor over till the mark you made is where you know BDC is. Easy ain't it? I use a sharpie to mark mine because I take my motors apart and inspect them often, and the sharpie will eventually cook away leaving me with no mark on the flywheel anymore. And when the sharpie mark is gone, then I know its time to take the mill apart and check things out. Put it back together, check BDC, make my mark, and let it rip. Hope this helps you out.
RC On The Plateau Crossville, TN
RC MOUNTAIN CROSSVILLE, TN
       Post #: 39
Jump to:
