HOW TO BREAK AN ENGINE IN!!!!!!
Tower Hobbies
Logged in as Guest
  Printable Version
Team Losi Muggy - RTR
Seller:  PastorVee
Details:   $1,100.00   |  10/10/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> HOW TO BREAK AN ENGINE IN!!!!!!
Page: [1] 2   next >   >>
Login
HOW TO BREAK AN ENGINE IN!!!!!! - 7/9/2008 1:34:27 AM
madmax22
Status: offline
Ok guys this question is popping up EVERY where. No offense to any one new to the hobby! But here is a couple ways to break an engine in!
First ill start by my way! ok first tank you can let idle with short blips of the throttle to keep it running. second tank get it on the ROAD (not on grass of dirt) and do 1/4 throttle passes. do the same thing for tank 3 but get a couple 1/2 throttle blips in there. 4th tank do some 1/2 throttle passes with some full throttle blips. 5th tank do 3/4 throttle with 1-2 seconds of WOT (wide open throttle) for the 6th thru 10th tanks you can do some WOT a little but not to much as the engine is still new. Always let the engine cool down before tanks with break in. Also after break in tanks get the engine at BDC (bottom dead center put it BDC every time you stop running)... Make sure with every tank your temps get up to at least 200 F...
Heat cycle: STEP 1: By using aluminum foil, heat tape or header wrap for full-size cars to block off cooling fins on the heat sink, you can somewhat manipulate the engine’s temperature so the engine can reach optimum temperature faster. Of course, that’s only if it’s not warm enough outside to allow the engine to build heat quickly enough.
STEP 2: While the engine is idling and warming up, leave the glow driver attached to the glow plug. This reduces the chance the engine might flame out early. Avoid revving the engine wide open to warm it up faster: that will actually wear out the piston and sleeve more quickly. You might see some of the guys at the local track doing it but believe me; this does more harm than good. You can give it some short moments of 1/4 throttle to help build engine temp and to keep the engine running while on the starter box.
STEP 3: While the engine cools between break-in runs, always, I mean ALWAYS make sure the piston is bottom dead center (BDC) when the engine is cooling.
STEP 4: After this first 15-minute break- in period, you should then run the engine in three 5-minute intervals. Again, make sure to let your engine cool down sufficiently between runs. Run at no more than half throttle with some short full-throttle burst. Again, make sure the engine gets up to temp and the piston is BDC (bottom dead center) each time when cooling. When the break-in process I described is finished, you will have a total of 30 minutes run time and break-in on the engine.
CONCLUSION!!!: Well, that’s all there is to it: Your engine is now properly broken-in. As you start tuning for racing, just remember that running rich is better, but the engine must get up to temp. Take your time when breaking-in your engine. Don’t rush the break-in process. If you rush it, you will only be rushing to the hobby shop to buy a new engine. The better you treat your engine during break-in, the better your engine will treat you. REMEMBER BDC after every time you use the engine!!!!
Hope i helped a little!!!!!
please dont hesitate to tell of any other ways or to make correction Thanks!
< Message edited by madmax22 -- 7/9/2008 3:56:07 PM >
_____________________________
They call me "butthead".......
       Post #: 1
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/9/2008 2:13:28 AM
twomanytoys
Status: offline
You say that during break ins the piston should always be at bottom dead center? Thats right to a point but ANYTIME you shut the engine off you should put the piston at bottom dead center. It dont matter if its durring break in or if it has 3 gallons on it. This will greatly increase the life of the pinch in the sleeve.
J et A ssisted T ake O ff
(in reply to madmax22)
       Post #: 2
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/9/2008 2:54:35 AM
madmax22
Status: offline
Thanks twomany!!!
(in reply to twomanytoys)
       Post #: 3
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/9/2008 3:10:01 AM
ericem
Status: offline
Agreed!! Probably why all my motors last over 8 gallons.
       Post #: 4
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/9/2008 3:28:37 AM
madmax22
Status: offline
lol i got 14 out of my TRX 2.5
(in reply to ericem)
       Post #: 5
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/9/2008 12:21:55 PM
droidswarm
Status: offline
I think I read somewhere that its important to get the temps upto 200 deg (ish) when attempting the heat cycle method, do you agree with that?
Following an accident involving 2 bottles of red wine and the internet I now own an HPI Firestorm!
       Post #: 6
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/9/2008 12:49:31 PM
st1_racer
Status: online
hey how do u know the piston is drop dead n the center, also i think this thread was started because of me lol
boogidy boogidy boogidy lets go racing boys
Thunder Tiger St1 is going to be sold/ Gs Racing Storm Cl-1. 1/8 Truggy kit
(in reply to droidswarm)
       Post #: 7
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/9/2008 12:52:07 PM
st1_racer
Status: online
whay about the old school way of just letting it idle?
       Post #: 8
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/9/2008 1:49:50 PM
SycoCell
Status: offline
Yes. Whenever you break in your truck, whether it's the traxxas or heat cycle method, you want the temps atleast at 200-210.
"I seemed to hit a speed bump!"
"No, that was just his Revo!"
       Post #: 9
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/9/2008 3:29:59 PM
Logi3
Status: offline
Yup make sure you get the temp to atleast 215f (IMO) running below 200f the liner is not exanding enough due to a low temp. Use foil like said above to raise the temp rather then using throttle on the first tank.
HN XR-C1 FTSE / Mugen MBX5T Prospec / TTR ST-1
Go .21 7 Port / Go .21 5 Port / Go .25 6 Port
(in reply to SycoCell)
       Post #: 10
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/9/2008 8:19:56 PM
Anomie
Status: offline
You can also compare notes to the Nitro Guide and FAQ thread in the Car Nitro & Gas Engines forum.
~Reiko~ RCU Car Forums Moderator
http://www.rcuniverse.com/forum/m_377662/tm.htm
       Post #: 11
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/9/2008 9:23:44 PM
rebelracer246
Status: offline
quote:
ORIGINAL: madmax22
i did it your way and i think it is alot better for the preformance of the motoe
http://www.youtube.com/watch?v=B6nJCigwtps
       Post #: 12
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/9/2008 10:09:47 PM
madmax22
Status: offline
yea i like my way the best. i like that you get to drive it a little in the first tanks
(in reply to rebelracer246)
       Post #: 13
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/10/2008 12:00:48 AM
madmax22
Status: offline
quote:
ORIGINAL: Reiko
sorry reiko but i think something needs to be here because newbies to the sight might not know where to look.... or people are just to lazy to look a little... you can lock or delete it if you want...
(in reply to Anomie)
       Post #: 14
RE: HOW TO BREAK AN ENGINE IN!!!!!! - 7/10/2008 1:40:40 AM
Technex
