mcculloch trimmer cc??? sx 80
Tower Hobbies
Logged in as Guest
  Printable Version
BCMA-MT 57 Pro - RTR
Seller:  blackbaron
Details:   $430.00   |  8/16/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> mcculloch trimmer cc??? sx 80
Page: [1]
Login
mcculloch trimmer cc??? sx 80 - 7/9/2008 2:55:12 AM
markaboo929
Status: offline
i can get a mcculoch sx 80 trimmer dirt chaep runs great real clean-just can't find the engine size on it no label or cc on it - can't find size on the net iether-it does have the pull starter on the back of it-making it firewall ready!!! just don't want to get something not werth the effort
       Post #: 1
RE: mcculloch trimmer cc??? sx 80 - 7/9/2008 1:18:39 PM
markaboo929
Status: offline
well i think it might be a kioritz? pull start is on the back of it and the muffler bolts on-dunnoi may just get it cause it really is almost perfect for rc airplane use-just need a prop hub really.
(in reply to markaboo929)
       Post #: 2
RE: mcculloch trimmer cc??? sx 80 - 7/9/2008 1:42:23 PM
Jim Dines
Status: offline
I have converted a McCullogh 28cc trimmer engine. A unique feature is that the muffler is held on by a spring. It's a good running engine but heavy. It will go in a 1/4 scale Sopwith Pup, so the weight will be OK in my application. I don't recall what the trimmer model designation was on mine.
       Post #: 3
RE: mcculloch trimmer cc??? sx 80 - 7/9/2008 1:58:33 PM
markaboo929
Status: offline
thanx-this muffler is bolted on i just may get it-too good to pass up-maybe go in a boat???
(in reply to Jim Dines)
       Post #: 4
RE: mcculloch trimmer cc??? sx 80 - 7/9/2008 3:05:19 PM
Ralphbf
Status: offline
I have a 28cc Mac also.
This motor runs very well on Gas-Glow.
_____________________________
Ralph
       Post #: 5
RE: mcculloch trimmer cc??? sx 80 - 7/9/2008 3:34:25 PM
rangerfredbob
Status: online
the engine he's talking about is a lot different than the 28/32 macs that are more popular, it's closer to 25cc, I have one, but haven't messed with it yet... and I agree, it's possibly a Kioritz, does it have some felt stuff covering the exhaust protector?
(in reply to Ralphbf)
       Post #: 6
RE: mcculloch trimmer cc??? sx 80 - 7/9/2008 6:37:42 PM
markaboo929
Status: offline
did nt look at it that good -but ill get it anyways-a guy i work with is into boats if it doesnt plan well for an aircraft-dunno hmm..maybe a .60 size stick plane engine?????
(in reply to rangerfredbob)
       Post #: 7
RE: mcculloch trimmer cc??? sx 80 - 7/9/2008 10:54:47 PM
buck1856
Status: offline
P{ost a pic,with out cases on.I uasally only do echos and stihls.One of us on here should be able to id it or tell what it is.
       Post #: 8
RE: mcculloch trimmer cc??? sx 80 - 7/10/2008 2:25:11 AM
markaboo929
Status: offline
don't have pics-not mine yet!!! gotta go 30 miles to get-BUT I can remember the rear pull starter has 3 bolts to hold it on instead of the usual 4 bolt ones you see on backpack blowers and such
(in reply to buck1856)
       Post #: 9
RE: mcculloch trimmer cc??? sx 80 - 7/12/2008 5:50:38 PM
markaboo929
Status: offline
well i got the trimmer today-no pics of it but i have the exact same one as listed on ebay here is a pic of the ebay one- mine is much claener and runs sweet!!!
http://cgi.ebay.com/Mcculloch-MAC-80A-grass-trimmer-parts-lot_W0QQitemZ110270051835QQihZ001QQcategoryZ71277QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
       Post #: 10
RE: mcculloch trimmer cc??? sx 80 - 7/13/2008 7:05:35 AM
buck1856
Status: offline
I just got rid of 2 of them.If mine where the same they would be the 22-23cc.Bolt pattern on the muffler should be staggered,in other words from corner to corner instead of straight across like the crank runs.Square cylinder.Carb throttle is already a straight shot to the servo.Not to bad running for a small weedie.
       Post #: 11
RE: mcculloch trimmer cc??? sx 80 - 7/13/2008 2:38:17 PM
Antique
Status: offline
If that engine is a Kioritz/Echo it's an older one and is 21.2cc's. These engines run nicely and turn a 15/8 or 16/4
       Post #: 12
RE: mcculloch trimmer cc??? sx 80 - 7/14/2008 2:33:21 AM
markaboo929
Status: offline
yes it has the staggerd exhaust bolt pattern.coolnow i know the mount is all set(built in 3 bolt) or can i use something for the FPE 1.3 engines? what about prop hub too and about the ignition go CDI or use coil + heavy mag..........hmmm oh great now i have to think of a plane for itdaam decisions -decisions-hey what about the new hangar 9 piper pawnee??? yeah it is a 40 size but-flying wieght is 8 lb or so-kinda heavy for a .40-.52-
(in reply to Antique)
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
