Installation Help
Tower Hobbies
Logged in as Guest
  Printable Version
HIMOTO Mamba or Eldorada 12MM HEX Wheel Extensions
Seller:  wheelextensions
Details:   $20.00   |  8/24/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> Installation Help
Page: [1]
Login
Installation Help - 7/9/2008 12:45:34 PM
tommygun32
From: San Diego but living in Dubai, UNITED ARAB EMIRATE
Status: offline
OK Guys,
As you may or may not know, these are Losi front and rear shock mounts that fit into the area of the lower swing arm where you would ususally install the bottom of the shock. I will have to do some slight modification of the lower swing arm to make them fit, however, I'm wondering how to secure them properly? They have two threaded holes that I should be able to screw into from the bottom. I don't really want to use plain washers, I was thinking of maybe getting a couple of small pieces of CF or alluminium and shaping them to fit flush inside the indentation of the lower side of the swing arm.
The reason for the installation of these on my Kyosho MP7.5 Kanai II is that I'm running 16mm big bore Hong Nor shocks and they rub against the dog bones as you can see in the last picture.
Your thoughts, as always, are highly appreciated.
Edit - Here's also a picture of what it's eventually supposed to look like.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by tommygun32 -- 7/9/2008 12:57:39 PM >
_____________________________
***The only stupid question, was the one you didn''t ask!***
       Post #: 1
RE: Installation Help - 7/9/2008 3:20:02 PM
Jerzferno
Status: offline
Tommy - Why are you using these? Why do you need them? They will push your Arms down lower, and you dog bones will pop out of the diff drive cups. You going to have problems unless you tighten way down on your limiting screws. If they are long enough? Then youll have hardly any suspension travel.
We can rebuild it!
MARBETH Nitro Sports
(in reply to tommygun32)
       Post #: 2
RE: Installation Help - 7/10/2008 8:56:00 AM
tommygun32
Status: offline
Hmmm...fair nuff. I'm just worried about the dog bone always rubbing against the bottom of the shock...(i know the answer to that one, run smaller diameter shocks..LOL)
(in reply to Jerzferno)
       Post #: 3
RE: Installation Help - 7/10/2008 12:33:07 PM
adam-69
Status: offline
Get some 4mm aluminium, angle the edges to fit that slot, drill two 3.5mm holes in each, countersink them, put in some m3 countersunk heads and thread lock them in, then tourqe them down tight.
damn, looks like ambition overcame adhesion again!
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.563RCU1
