Dumb Question
Tower Hobbies
Logged in as Guest
  Printable Version
Wheely King 14mm Hex Wheel Extensions - RTR
Seller:  wheelextensions
Details:   $20.00   |  8/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Nitro Stadium Trucks >> Dumb Question
Page: [1]
Login
Dumb Question - 7/9/2008 1:33:17 PM
basherjordan
Status: offline
Ok guys, dumb question for ya.
on the gt2, the slipper clutch is the nut with the spring thing that comes out of the spur gear right? (sorry for the bad explanation)
And, what is the right setup for the slipper clutch?
i tried to take of my spur gear, and i unscrewed that nut all the way, and i dont remember exactly where it was
if anyone can help, that would be awsome.
thanks
_____________________________
>-Live your live a fuel tank at a time-<
>Ofna MBX Comp LRP Z.28 Spec 3<
       Post #: 1
RE: Dumb Question - 7/9/2008 2:08:32 PM
Stang444
Status: offline
Not exactly a dumb question... There isn`t an exact "setting" where it goes no matter what. Ok: I do this: screw it on, turn it 5 times, and test it. Too tight? Or to loose? If its 2 tight, loosen it 1 turn. if its too loose, tighten it 2 turns. and keep doing that untill your happy.
Hope this helps
Trent
(in reply to basherjordan)
       Post #: 2
RE: Dumb Question - 7/9/2008 7:07:00 PM
Checkpointracer
Status: offline
^^^What Stang said.
I just turn it until I think it's right, not too tight or not too loose.
Keep them behind you or crash hard trying.
(in reply to Stang444)
       Post #: 3
RE: Dumb Question - 7/9/2008 8:26:02 PM
robbio4422
Status: offline
kinda funny this was brough up... i replace the spur gear on my rusty yesterday and when i fired her up my nut was a bit loose.. at first i thought i was just spinning my tires and had a CRAP load more power (with anacondas on the rear) then i realized it was jsut the clutch spinning so i gave it another turn and a half and it was all good!
my gt brings all the girls to my yard
(in reply to Checkpointracer)
       Post #: 4
RE: Dumb Question - 7/11/2008 10:09:03 PM
basherjordan
Status: offline
how can you tell if its too tight or too loose?
what will the car do if it is too tight or too loose?
(in reply to robbio4422)
       Post #: 5
RE: Dumb Question - 7/12/2008 12:28:14 AM
Stang444
Status: offline
well theres not an easy way to tell if its too tight....I would just start loose and make small increments. If its too loose it`ll revv up the eng. but wont go much. well you dont want breakneck acceleration...so tighten it till it doesnt slip and then back it off maybe 1/4 turn.
       Post #: 6
RE: Dumb Question - 7/12/2008 3:21:50 AM
nitrosport963
Status: offline
i had my nitro sport out and it was all good then i would be full throttle and it was acting like it was half throttle
       Post #: 7
RE: Dumb Question - 7/12/2008 6:20:36 AM
mojavemonster
Status: offline
This is what I do....get a metal spur and tighten that sucker all the down. Never had any problems....but thats jus me.
Creator of......Project Hard-CORR
(in reply to nitrosport963)
       Post #: 8
RE: Dumb Question - 8/22/2008 5:30:53 AM
Mindless_Chaos
Status: offline
quote:
ORIGINAL: mojavemonster
That is not smart. The slipper has more functions then just protecting the spur gear. You can also adjust it so that you will get less spin out and more traction on the track. If your tires are spinning out then you have less control.
Also, with a metal spur gear, you can eat the bell pinion gear if the slipper is too tight. I ate 2 of them when the nylon washer in the locknut wore out and tightened on its own. Not only did I eat 2 Bell pinion gears, but I tore up the slots in the wheels that the pin sets in and had to get new wheels.
basherjordan: It all depends on how you are tuning it. You don't want it too tight because this takes the stress off the rest of the drive train. Also you can loosen it to get less spin out for better traction on the track. you don't want it too loose or it will spin and not put full power to the wheels and you will loose tourq and speed. Just play with it till its right.
For instance. I have a .18 on my RC10GT and its got mega power. So much so that in half throttle in a cruise I can throttle it all the way and it will wheelie like crazy, not to mention it will almost jump in the air of the start. This is no good for control on the track. So i loosen the slipper until I can full throttle and the wheels will just barely stay down. and down enough to still have steering grip on the front tires with out loosing power I don't need too.
its all tuning for what you want to achieve. If you want to do wheelies like crazy and spin out like nuts, then you want to tighten it up a lot. But it should still be just loose enough to take some of the stress off the drive train if need be.
< Message edited by Mindless_Chaos -- 8/22/2008 5:36:09 AM >
(in reply to mojavemonster)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.656RCU1
