14mmx1.25 Die find one?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Conversions >> 14mmx1.25 Die find one?
Page: [1]
Login
14mmx1.25 Die find one? - 7/9/2008 4:50:13 PM
frenchie79
Status: offline
I have searched for a Die that has the same threads as most spark plugs-14x1.25 and cannot find one. Is their such an animal, or do i even have the threads correct. Even Master car catalog don't carry it. Any ideas out their.
_____________________________
Frenchie #193
       Post #: 1
RE: 14mmx1.25 Die find one? - 7/9/2008 6:19:40 PM
Dr Honda
Status: offline
That's the right size, but it's a very fine thread. You may have to contact a tool shop overseas to get it. I'm a manufactuer, and I have a hard time just finding metric stainless fine thread bolts sometimes.
The easyest thing to do is... if you only need one or two parts... find someone with a lathe, and have them cut the threads for you.
What are you trying to do?
< Message edited by Dr Honda -- 7/9/2008 6:22:25 PM >
Tony
Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
(in reply to frenchie79)
       Post #: 2
RE: 14mmx1.25 Die find one? - 7/9/2008 7:13:42 PM
frenchie79
Status: offline
I want to make my own adapter for glow conversion. I know i can order one, but thats not as much fun as making the parts. I have a lathe and looks like i'll be cutting threads. Having a Die would be quick and easy. The search continues.
Frenchie #193
(in reply to Dr Honda)
       Post #: 3
RE: 14mmx1.25 Die find one? - 7/9/2008 8:17:20 PM
nitro joe
Status: offline
quote:
ORIGINAL: frenchie79
This fellow made one from a sparkplug.
I believe he posts in this forum at times
Click to see fullsize image.
Click for fullsize
Information on the Internet is subject to the same rules and regulations as conversation at the corner Pub -Author unknown.
       Post #: 4
RE: 14mmx1.25 Die find one? - 7/10/2008 3:06:39 AM
av8tor1977
Status: offline
I just make mine from old spark plugs usually. Or you can order one from Horizon Hobbies for 10 bucks...
AV8TOR
If it's not scary, it's NOWHERE NEAR powerful enough!!
(in reply to nitro joe)
       Post #: 5
RE: 14mmx1.25 Die find one? - 7/10/2008 4:19:09 AM
captinjohn
Status: offline
Try Ralph rcignition.com or call 1-928-635-2455. Best price around! Capt,n http://www.usrainfo.org/manufac.htm
< Message edited by captinjohn -- 7/10/2008 4:21:25 AM >
I never met a engine I did not like!
(in reply to av8tor1977)
       Post #: 6
RE: 14mmx1.25 Die find one? - 7/10/2008 5:16:59 AM
nitro joe
Status: offline
quote:
ORIGINAL: captinjohn
The gentleman seems to be looking forward to the challenge of cobbling up his own adapter.
I’m confused, is RCIGN now selling budget priced spark plug thread dies?
(in reply to captinjohn)
       Post #: 7
RE: 14mmx1.25 Die find one? - 7/10/2008 5:59:05 AM
rangerfredbob
Status: offline
he sells glow plug adapters
what I've done to make adapters is take an old spark plug (saved from the trash at work), removed the porcelin (stuck it in the lathe and cut the crimp off), turned it down to shorten it, shortened the threads so there's only like 3 left (they were small block chevy plugs, long threads), made an aluminum plug to go down the middle and pressed that in, drilled that out to the right size to tap to 1/4-32, then tapped the middle, I used the lathe to cut the right threads onto a 1/4" bolt shaft, then slotted the sides of the threads so it would work as a tap. I haven't ran on this adapter, but it should work
       Post #: 8
RE: 14mmx1.25 Die find one? - 7/10/2008 1:48:02 PM
frenchie79
Status: offline
Called this guy every day this week and no answer. Ended up buying some ignitions from CH. I do want to make my own. I have a shop and need to use it, part of the fun of conversion. Money is not an issue, just enjoying making things work-You Know?
Frenchie #193
       Post #: 9
RE: 14mmx1.25 Die find one? - 7/10/2008 1:52:51 PM
frenchie79
Status: offline
Did the same thing with a regular plug from a trimmer. I haven't press fit the ALm in yet, waiting on a 1/4 x32 plug tap. I'm not sure about the press fit with vibration and different metals. I think it will blow out in a short time. It would be like a bullet.
Frenchie #193
(in reply to rangerfredbob)
       Post #: 10
RE: 14mmx1.25 Die find one? - 7/10/2008 3:33:07 PM
rangerfredbob
Status: offline
aluminum expands more than steel, and it's inside, plus if you're really worried, get some green loctite, the one labeled "sleeve retainer", that'll hold it for sure, or just machine a step in the end of the aluminum that would go twards the combustion chamber, a physical stop...
< Message edited by rangerfredbob -- 7/10/2008 3:34:18 PM >
       Post #: 11
RE: 14mmx1.25 Die find one? - 7/10/2008 3:57:10 PM
frenchie79
Status: offline
Putting the step in is what i thought. This would be a very simple a fast way to make these. I'll post a shot of one finished.
Frenchie #193
       Post #: 12
RE: 14mmx1.25 Die find one? - 7/11/2008 3:55:11 AM
captinjohn
Status: offline
quote:
ORIGINAL: nitro joe
HE (rcign)does not cobbel anything....he sells the adapters already made. Call in eve...he is out west!
       Post #: 13
RE: 14mmx1.25 Die find one? - 7/11/2008 4:38:22 AM
nitro joe
Status: offline
quote:
ORIGINAL: nitro joe
Huh?
The gentleman in the posting said he wants to make his own adapter.
He stated he does not want to buy one,but is looking for a die.
Some of us run into tooling(dies in this case) we could use with our machine tools at home.
Nitro
       Post #: 14
RE: 14mmx1.25 Die find one? - 7/11/2008 1:29:06 PM
Dr Honda
Status: offline
This was a quick Google search. Hummmmmm... I seem to have somthing in my mind about the time looking Vs the time posting... Anyway... there you go.
$52!! (good HHS)
http://www.metric-tools.com/catalog/item/4024227/3812370.htm
$17 (carbon steel, but will get the job done)
http://www.amazon.com/Carbon-Steel-Hexagon-Across-14mm-1-25/dp/B000K1E5SW/ref=sr_1_7?ie=UTF8&s=automotive&qid=1215778949&sr=8-7
< Message edited by Dr Honda -- 7/11/2008 1:30:28 PM
