question about clutch bells....
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> HPI Monster Truck Forum >> question about clutch bells.... Page: [1]
Login
question about clutch bells.... - 7/10/2008 9:20:04 PM
dadirtsavage
Status: offline
I'm running the optional 49tooth spur gear and it works really good for both torque and speed i noticed. im also using the original savage clutch bell. but i wanna get a clutch bell that will improve the performance so im confused as to what amount of teeth would be good for a 49 tooth if anyone has experience with them....thankls
       Post #: 1
RE: question about clutch bells.... - 7/10/2008 11:21:46 PM
BudBud
Status: offline
If you are having good luck the way you are running, just match your current bell. If you want a little more speed and a little less power, go up a tooth. If you need less speed and want a little more power, go down a tooth. Up would be 13 to 14, down would be 14 to 13. A tooth does not sound like a lot, but it add up in a hurry. For example a 14 bell on your 49 is a 3.5 ratio, or one rotation of the transmission shaft for every 3.5 rotations of the crank shaft. A 13 would be a 3.77. BB
_____________________________
Doing my best to fill a 55 gallon drum with broken or worn out R/C parts.... 8^)
(in reply to dadirtsavage)
       Post #: 2
RE: question about clutch bells.... - 7/10/2008 11:53:48 PM
dadirtsavage
Status: offline
quote:
ORIGINAL: BudBud
thanks for that. so I want more torque. and i want to use 49tooth spur, go down one tooth, which would be a 12? or a 13? i just want more torque
(in reply to BudBud)
       Post #: 3
RE: question about clutch bells.... - 7/11/2008 1:46:37 AM
mazdab2600
Status: offline
gearing chart.
old and blurry. will have to make a new one soon.
f4.6/lrp spec3/piccop3.26 monster/picco p3.28/axial spec1.28
byrons 30%5 trucks.savage strong you bet.
       Post #: 4
RE: question about clutch bells.... - 7/11/2008 1:51:33 AM
dadirtsavage
Status: offline
quote:
ORIGINAL: mazdab2600
gearing chart.
thanks for that.
(in reply to mazdab2600)
       Post #: 5
RE: question about clutch bells.... - 7/11/2008 1:53:00 AM
hpdrlr
Status: offline
what do the colors represent
       Post #: 6
RE: question about clutch bells.... - 7/11/2008 1:53:53 AM
dadirtsavage
Status: offline
quote:
ORIGINAL: hpdrlr
thas the only thing i nevr undertstan
(in reply to hpdrlr)
       Post #: 7
RE: question about clutch bells.... - 7/11/2008 1:58:17 AM
BudBud
Status: offline
I think the reds are no gos, as you do not have enough room to run a 52 and a 20, the 13 and 47 must not come close enough together. I am not sure what the blues are. BB
       Post #: 8
RE: question about clutch bells.... - 7/11/2008 2:05:51 AM
dadirtsavage
Status: offline
blues im guessing is an okay way for a gear ratio but maybe not reccomended....
       Post #: 9
RE: question about clutch bells.... - 7/11/2008 2:22:07 AM
mazdab2600
Status: offline
blue is depending on the engine clearance to the tvp.
sorry for leaveing the colour codes out.
being at work sucks but the pay is good.lol
       Post #: 10
RE: question about clutch bells.... - 7/12/2008 12:23:24 AM
hot rod 10
Status: offline
That chart will work,but you also have to consider engine size and power also
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
