Can anyone help me with this Smoker
Tower Hobbies
Logged in as Guest
  Printable Version
Dave Patrick Models Extra 330L - RTF
Seller:  cdp2buck
Details:   $845.00   |  10/7/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Questions and Answers >> Can anyone help me with this Smoker
Page: [1]
Login
Can anyone help me with this Smoker - 7/10/2008 9:50:02 PM
kid chuckles
Status: offline
I was given this smoke pump set up by an older gentleman but do not have a clue as to how it works. You can see everything it the pitcures i think.
The small deal the servo arm is on I think is the pump. There are two small threaded bolt sticking out. Does the battery hook to them maybe? And the small things with line nipples are what? I want a smoke pump but man this is not like any I have seen. I have only seen a sullivan. Thanks for any help fella's.
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 1
RE: Can anyone help me with this Smoker - 7/10/2008 9:56:46 PM
Flying freak
Status: offline
Intresting setup what the servo is hooked up to looks like a valve to me, The 2 black thigns with the blue tubs are pumps normaly usedto supply fuel to the engine... theye run off engine vibration and not any electrical setup...
Steven
(in reply to kid chuckles)
       Post #: 2
RE: Can anyone help me with this Smoker - 7/10/2008 11:21:00 PM
pmw
Status: offline
Just guessing I would say the servo is connected to an on/off valve. The two black items are Perry pumps that must supply the pressure for the fluid, but I would think they might not supply it at very high pressure. The other item is a needle valve, probably used to control the flow rate of the smoke fluid. I've never heard of using Perry pumps for smoke, but it's a good idea. No electrics and few leaks.
Paul
_____________________________
PMW
(in reply to Flying freak)
       Post #: 3
RE: Can anyone help me with this Smoker - 7/11/2008 12:17:03 AM
JohnBuckner
Status: offline
It is a Perry/Varsane/Conley smoke system. You actually have two VP-20 ossilating pumps there. One is used for the smoke system. It is mounted on the backplate of the engine itself and oriented in the plain of rotation (it will not work on the airframe itself). There is a molded in arrow to indicate the flow direction.
The device with the servo is the pinch off type flow control for shutting the smoke on and off. The other little device is an oil needle valve to adjust the flow volume. The servo valve would be used between the tank and pump and the flow control needle would be used between the pump and the muffler or preheater coils.
This picture shows the proper orientation for mounting the VP-20, it could also be used on the bottom side 180 degrees on back plate mount. The ossilating pump can be use for either smoke oil or fuel, in this installation is pumping fuel:
John
Click for fullsize
< Message edited by JohnBuckner -- 7/11/2008 12:23:09 AM >
"Keep your controllines tight"
(in reply to pmw)
       Post #: 4
RE: Can anyone help me with this Smoker - 7/11/2008 12:52:58 PM
kid chuckles
Status: offline
Thanks guys somone one here knows about almost everything RC related amasing. Was going to put it on a Frenzy 100 but man there is just no room for it. Thanks again.
(in reply to JohnBuckner)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.594RCU1
