Team Orion Baja. Please Help!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> Team Orion Baja. Please Help!
Page: [1]
Login
Team Orion Baja. Please Help! - 7/11/2008 1:58:23 AM
Wepo
Status: offline
Alright so I just got my motor and it didnt come with wires. Is this what I need? Link***
< Message edited by Wepo -- 7/11/2008 4:49:53 PM >
       Post #: 1
RE: right so I just got my motor Team Orion Baja Help - 7/11/2008 2:00:52 AM
Wepo
Status: offline
also im not quiet sure where i need to solder the wires
(in reply to Wepo)
       Post #: 2
RE: right so I just got my motor Team Orion Baja Help - 7/11/2008 4:39:33 PM
Wepo
Status: offline
Please help me here because i need to get this motor in the car before next weekend. Is that the right wire is what im asking and also where do i solder the the wire and what color is negative whats positive. most of my motors are marked with a red mark to indicate the red wire. this motor just has a positive sign. so what color is positive. please help me out here. thanks
(in reply to Wepo)
       Post #: 3
RE: right so I just got my motor Team Orion Baja Help - 7/11/2008 5:17:51 PM
Wepo
Status: offline
I think I need to solder the top left and bottom right of the pic. Anyone who has this motor could you please check? Thanks!
Click to see fullsize image.
Click for fullsize
(in reply to Wepo)
       Post #: 4
RE: right so I just got my motor Team Orion Baja Help - 7/12/2008 2:44:46 AM
Wepo
Status: offline
Took a shot at where i thought it should be soldered and wah lah! Its up and running now i just need my new pinion to come in so i can acctually run this thing.
(in reply to Wepo)
       Post #: 5
RE: Team Orion Baja. Please Help! - 7/12/2008 3:54:09 AM
buster7467
Status: offline
What are you running it in?
(in reply to Wepo)
       Post #: 6
RE: Team Orion Baja. Please Help! - 7/12/2008 6:54:59 AM
Wepo
Status: offline
Mini-T I threw it in and ran it once and wow its amazing. Ive never gotten that much out of an brushed motor. I cant wait till i break it in a little and get some serious speed out of it.
(in reply to buster7467)
       Post #: 7
RE: Team Orion Baja. Please Help! - 7/12/2008 7:58:49 AM
buster7467
Status: offline
What size pinion are you using. The stock plastic pinion will not stay on the shaft for very long. Even with CA glue on it, it will still come off when the motor shaft gets warm. I had one in my mini t when i raced it and i used the 9,10,11,12,17 tooth pinions. If you use aftermarket pinions you will have to file a flat spot on the motor shaft for the set screw on the pinions.
(in reply to Wepo)
       Post #: 8
RE: Team Orion Baja. Please Help! - 7/12/2008 8:16:42 AM
Wepo
Status: offline
Wish i knew that before i started trying to drive in in the driveway without gear box on. my Golden Horizons 9t is gone. I have a 15t gh pinion on the way should this be fine? Also how do you file down a flat spot on the shaft i havent ever had to do this before.
       Post #: 9
RE: Team Orion Baja. Please Help! - 7/12/2008 8:21:45 AM
buster7467
Status: offline
I used a dremel tool to do mine. Yea it is a good idea to run the mini t with the gear cover on so you wont lose your pinion. If you are just running on smooth pavement and not offroad then the 15t should be fine.
(in reply to Wepo)
       Post #: 10
RE: Team Orion Baja. Please Help! - 7/12/2008 5:44:07 PM
Wepo
Status: offline
is there anything else i can use because i dont have a dremel right now. Also i will be sand bashing so but its smooth sand. I have ran the stock baja on it no problems. So i think ill be fine. but yeah what else could I use to flaten the shaft
       Post #: 11
RE: Team Orion Baja. Please Help! - 7/12/2008 5:48:04 PM
buster7467
Status: offline
You can use a small metal file. The flat spot that needs to be put in the shaft really only has to be tiny. Just big enough for the set screw in the pinion to fit in.
(in reply to Wepo)
       Post #: 12
RE: Team Orion Baja. Please Help! - 7/12/2008 6:06:30 PM
Wepo
Status: offline
alright thanks for the help
       Post #: 13
RE: Team Orion Baja. Please Help! - 7/13/2008 5:47:56 PM
Wepo
Status: offline
so only as big as the set screw?
(in reply to Wepo)
       Post #: 14
RE: Team Orion Baja. Please Help! - 7/13/2008 6:47:56 PM
buster7467
Status: offline
Yes
(in reply to Wepo)
       Post #: 15
Page:   [1]
Page: [1]
