Braking with Futaba 3PM
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> Braking with Futaba 3PM
Page: [1]
Login
Braking with Futaba 3PM - 7/11/2008 11:06:48 AM
Swingnamiss
Status: offline
When I apply the brakes on my Futaba 3PM it leaves the car at wide open throttle. Does anyone have a clue as to why this is?
       Post #: 1
RE: Braking with Futaba 3PM - 7/11/2008 1:54:58 PM
Draker1
Status: offline
what about when you give it gas,does it stop?
Maybe you need to reverse the servo?
(in reply to Swingnamiss)
       Post #: 2
RE: Braking with Futaba 3PM - 7/11/2008 11:28:35 PM
adam-69
Status: offline
if it isnt as stated above, are the brakes epa set to 0%? could mess it up?
I would place my bets on the above post though.
< Message edited by adam-69 -- 7/11/2008 11:29:10 PM >
_____________________________
damn, looks like ambition overcame adhesion again!
(in reply to Draker1)
       Post #: 3
RE: Braking with Futaba 3PM - 7/11/2008 11:42:50 PM
JsK
Status: offline
Check your brake mixing channel.
(in reply to adam-69)
       Post #: 4
RE: Braking with Futaba 3PM - 7/12/2008 4:29:40 AM
hrdcoreglf
Status: offline
Just read the manual. It tells you haw to reverse servo setting for throttle/brake.
Wisdom is only as good as the person you give it to.
       Post #: 5
RE: Braking with Futaba 3PM - 7/12/2008 5:17:17 AM
ThunderbirdJunkie
Status: offline
what happens when you PULL the trigger? if it applies the brake, then reverse your servo. If the engine revs when you hit the brake, but the brakes are applied, you f'd up with your linkages.
"Some people can mess up an anvil with a rubber hammer"-46u
(in reply to hrdcoreglf)
       Post #: 6
RE: Braking with Futaba 3PM - 7/12/2008 6:06:53 AM
Swingnamiss
Status: offline
Hey guys I checked servo settings and they were good but what I did notice was that instead of using the servo horn that came with the Ace servos I used the ones that came with the kit and they stripped, thats what caused it to go WOT. Well I havent tried it again yet as now Im about to readjust my throttle/brake linkage so it doesn't hit they tank when I throttle it.
(in reply to ThunderbirdJunkie)
       Post #: 7
RE: Braking with Futaba 3PM - 7/12/2008 6:10:22 AM
tommygun32
From: San Diego but living in Dubai, UNITED ARAB EMIRATE
Status: offline
I had the same problem. You may just need to cut a small bit off the end of the linkages that are hitting the tank when your throttle is at full throw.
***The only stupid question, was the one you didn''t ask!***
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.953RCU1
