beer=food
Joined: 11/26/2007 From: hervey bay, AUSTRALIA Status: offline
There is no reason why it wont work, it will work fine if you get the sizes right so everything fits good, but an internal spring/shock set up isnt new, l cant see why it wouldnt work, the top of the shock housing has to be strong, if its threaded on the thread needs to be a deep one so you get massive strength through the threads surface area. It will work, what you loose is some distance your shock can move, the room the spring takes up when compressed, these designed shocks are used in rally cars and on road cars, there is NO need for a stainless steel spring, its covered in oil 24/7, a normal rated spring will do. If your worried about the shock absorbancy of the shock, maybe think about resovars for em, gets pretty complex but then, your basic design will work fine, be tough as any you can buy, as adjustable as any, just cant seee a reason why it wouldnt work as good or better than the Rc shocks you buy, lets face it Rc shock systems are pretty basic, compared to real shock absorbers !
_____________________________
my revo is a bird, my baja a brick, when l get em airbourne, its really quite sick, all fun and games till they come back down, and l land em like a frootloop backwards-arss clown !
