grp starting?
Tower Hobbies
Logged in as Guest
  Printable Version
Tamiya Land Cruiser CR-01 Crawler Assembled w/ ESC - Kit
Seller:  sheograth
Details:   $300.00   |  9/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> grp starting?
Page: [1]
Login
grp starting? - 7/11/2008 5:44:10 PM
phast46
Status: offline
this winter im building a buggy, and this is the engine i would like to put into it. how would i start this, is it roto start? bump box?
http://www.amainhobbies.com/product_info.php/cPath/1_23_31/products_id/23443
_____________________________
BRAAAAAP Jato 3.3 TL EIGHT(soon)
       Post #: 1
RE: grp starting? - 7/11/2008 5:48:21 PM
qaiz
Status: online
You'll need a bump box for that engine. I highly doubt if you'll be able to get a roto start for that engine, but I might be wrong...
Emirates Hobbies
Support your LHS.!
(in reply to phast46)
       Post #: 2
RE: grp starting? - 7/11/2008 5:49:10 PM
McFly505
Status: offline
You will need a starter box for that.
Scott
AE RC8-OS Speed, AE RC8-OS V Spec, AE RC8T-Coming soon!!!
       Post #: 3
RE: grp starting? - 7/11/2008 5:55:32 PM
phast46
Status: offline
is the starter box a hassle to carry?like if i have to go down the road with my car will i be able to fit a starter box into my backpack? along with a remote?
(in reply to McFly505)
       Post #: 4
RE: grp starting? - 7/11/2008 5:57:20 PM
qaiz
Status: online
quote:
ORIGINAL: phast46
Should be fine, as for weight, it can all depend. I use NiMH Stick Packs ( 14.4V ) and the box I use is quite light, switch over to a Gel Cell ( 12V Lead Acid Sealed ), and its a whole other story, 12V's are extremely long lasting but extremely heavy at the same point..
Emirates Hobbies
Support your LHS.!
       Post #: 5
RE: grp starting? - 7/12/2008 8:26:44 AM
McFly505
Status: offline
No 'Jail' cell for me......
OFNA truggy box with one of these, weighs next to nothing.
I'll never go back to gel cells.
Scott
(in reply to qaiz)
       Post #: 6
RE: grp starting? - 7/12/2008 2:12:51 PM
phast46
Status: offline
thanks, but does that die easy?
       Post #: 7
RE: grp starting? - 7/12/2008 4:11:04 PM
911
Status: offline
No they last very long and can hold a charge, but it will cost you an arm...
Even more if you don't already have a Lipo compatible charger...
Read my post twice before replying cause you might not get my sarcasm the first time around...
       Post #: 8
RE: grp starting? - 7/12/2008 6:32:03 PM
phast46
Status: offline
i think ill probally just go with a 12 volt gell cell, i think that would be the next best thing.
(in reply to 911)
       Post #: 9
RE: grp starting? - 7/12/2008 7:31:55 PM
qaiz
Status: online
quote:
ORIGINAL: phast46
No, the next best thing is 2 7.2V NiMH stick packs, the last resort is the 12V IMO.
Emirates Hobbies
Support your LHS.!
       Post #: 10
RE: grp starting? - 7/12/2008 9:39:49 PM
McFly505
Status: offline
2 weekends on a single charge.
It took a 600 ma charge after that.
$69.99 @ A main.
I also use 2 stick packs in my AE box.
2 3600 Venom packs last all weekend and then some.
The downside to the Lipo is that you need a lipo charger and a balancer, which adds to the bottom line.
BUT, once you try it, you won't mess with anything else.
I have another Lipo pack coming for my AE box.
2 decent stick packs will set you back $35-$40 plus you still need a decent charger to make them last longer than a month.
A gel cell and a 12V charger will set you back about the same $$$ and doesn't offer the voltage of the other two options and weighs a TON.
On a single charge, my 12V gel cell would only work good for a couple weekends before getting too weak to start a car.
My $.02
Scott
(in reply to qaiz)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
