BudBud
KS, USA Status: online
I am not so sure you need to start all over from stock settings. One thing to check is that the mid needle has not backed out any, it should be flush and most of us leave it alone.. I take it that it is slow taking off. Get it running in an area that you can run wide open, warm it up and run it hard for a few minutes. It should blow smoke and obtain a high pitched sound like the K4.6 in this video. When you get that high speed rip going on, you set the low speed needle. If it is sluggish off idle and blows a lot of smoke, it is too rich. If it bogs and has little smoke it is too lean, which is dangerous for your engine. A YouTube search for RC tuning will take you to two great tuning videos by our friends at HPI. Always get the high speed wailing first, then set the low needle as the HSN changes the Low needle. You will soon find yourself with a pretty basic low setting and bumping your HSN back and forth for temperature and humidity changes. If you want to be safe, turn the HSN needle richer 1/8th of turn first to see of you get less perfromance and more smoke. If you do, you are too rich. In this video, I have an engine that is too lean on the low side. Even though it blows a huge cloud of smoke initially, as it builds heat, it has run on as the engine idles down. It was very close, I think an 1/8th is all I had to give it to get it here. You will find that some fuels flow easier than others and you will have to go leaner than Hpi recommends to get the mixture right. It is a lot better problem to have than the other way. When they are always trying to go lean on you, someplace there is an air leak. On the Axials and Hpi K engines, it is almost always the front bearing. BB
_____________________________
Doing my best to fill a 55 gallon drum with broken or worn out R/C parts.... 8^)
