hitec servo ????
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> 3D Flying! >> hitec servo ???? Page: [1]
Login
hitec servo ???? - 7/12/2008 1:01:27 AM
outacntrl
Status: offline
got 5645's in my new gasser and noticed that the elevator servos (dual) move same till i get to the upper throws, then the one continues to move aftr the other has stopped.( just a few deg's).. there is a servo reverser lead on them and when i installed it i did notice a small potentiometer (spelling sucks) on the small ckt. brd in the reverser lead . is that for tuning them to work the same ..did'ent want to jst start turning it.. anybody seen this ?? all the stuff is brand new..thanx tim
       Post #: 1
RE: hitec servo ???? - 7/12/2008 2:14:30 AM
BarracudaHockey
Status: offline
What radio?
_____________________________
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
(in reply to outacntrl)
       Post #: 2
RE: hitec servo ???? - 7/12/2008 7:03:41 AM
MetallicaJunkie
Status: offline
your geometry could be off.... another possiblity is that not all elevator halves move equally, if your hinge gap is more on one halve, it will travel further, and you will have to adjust your your endpoint to the elevator halve that moves less..... sounds confusing but ive experienced that before...
if you need a a reversed servo i take it you dont have a computer radio.... or do you?
Freestyle Junkie
Revver Bro #217
(in reply to BarracudaHockey)
       Post #: 3
RE: hitec servo ???? - 7/12/2008 8:34:06 AM
victorzamora
Status: offline
outacntrl, that's exactly what the potentiometer is for. Worse comes to worse, you can always set it back to where it was .
(in reply to MetallicaJunkie)
       Post #: 4
RE: hitec servo ???? - 7/12/2008 8:50:45 AM
freeair
Status: offline
when running 2 individual servos such as elevator control, you must make sure both elevator arms / links are set at the same distance so both will have equal throws. if one arm is slightly out from the other side arm you won,t have the same throws. have a close look at the elevator arms and compare how even they are to the stab, if one is 1mm off you have the problem.
(in reply to victorzamora)
       Post #: 5
RE: hitec servo ???? - 7/12/2008 5:19:23 PM
Taildragger726
Status: offline
Uhhh, It ain't the servo,,,,
(reverser! )
Also known as N726AC
(in reply to freeair)
       Post #: 6
RE: hitec servo ???? - 7/12/2008 11:07:47 PM
outacntrl
Status: offline
thanx for the input.. the radio is a fut. 6ex i'll check all the things mentioned and chk back soon..the radio is more less a entry level, had it for a cpl yrs..fly'n my 40 size stuff .i hav'ent touched the potentiometer......yet . i'll check things before i tweak the pot just to see....thanx tim .........ok thoughly examined her & yes the one hinge gap is 1/2mm larger, and the horn is prolly a 1/2mm diff. i cked out the pot adj to see how that works ..tweaked it jst a smidge and now there good thanx all, you guys are great..tim
< Message edited by outacntrl -- 7/13/2008 2:28:43 AM >
(in reply to Taildragger726)
       Post #: 7
RE: hitec servo ???? - 7/15/2008 9:15:50 PM
Jezmo
Status: offline
Yep, you figured it out. That's what the pot does. Happy flyin.
Raptor 50 V2 OS 50 Hyper, T-Rex 450XL CDE, Spektrum DX7, SuperTigre OS FOX Saito Enya Jett TT
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.457RCU1
