AccuCycle Elite power supply for Eflite Charger?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> AccuCycle Elite power supply for Eflite Charger?
Page: [1]
Login
AccuCycle Elite power supply for Eflite Charger? - 7/12/2008 1:31:16 AM
Geardaddys
Status: offline
Fellas..
Have any of you used the power supply for the AccuCycle Elite as a AC power source for the EFlite lipo charger that comes with the Blade 400? I tried it last night and couldn't get the Eflite charge to power up.. It doesn't make sense though, the accucycle power supply has an output of 14.5 Volts at 2.5Amps.. I think that the B400 charger will take up to 15Volts.. I tried several ways to connect (alligator clips/bannana clips, and a deans plug that I made to charge my lipos with..) Anyway, no power, no lights.. confusion..?
GD
       Post #: 1
RE: AccuCycle Elite power supply for Eflite Charger? - 7/12/2008 2:47:51 AM
autoart4you
Status: offline
the eflight eflc3115 takes 11.5V ~ 15.0V =::: 1.5a? neg. - on outside and pos.+ on inside post
< Message edited by autoart4you -- 7/12/2008 3:00:25 AM >
_____________________________
If you can''t race it or take it to bed,
it''s not worth having!
(in reply to Geardaddys)
       Post #: 2
RE: AccuCycle Elite power supply for Eflite Charger? - 7/12/2008 3:04:28 AM
Geardaddys
Status: offline
Yeah, I had the pos/neg right.. I just don't understand why I couldn't get it to power up..
(in reply to autoart4you)
       Post #: 3
RE: AccuCycle Elite power supply for Eflite Charger? - 7/12/2008 3:13:03 AM
autoart4you
Status: offline
do you know that it works? i have the AccuCycle Elite and the eflc 3115 it looks like it would work with bannana clips and a neg. on outside and pos. on inside post plug???? IDK, lol, you got me man???
       Post #: 4
RE: AccuCycle Elite power supply for Eflite Charger? - 7/12/2008 3:30:47 AM
Geardaddys
Status: offline
Yeah, that's what I though.. The Eflite Charger comes with a cable that plugs into the charger, and two aligator clips on the ends.. I'll have to try it again, but I couldn't for the life of me figure out why it wasn't working.. I even tried a different power outlet figuring that my power outlet must have been "off" I was so sure that it would work!
       Post #: 5
RE: AccuCycle Elite power supply for Eflite Charger? - 7/12/2008 3:37:56 AM
autoart4you
Status: offline
good luck!
       Post #: 6
RE: AccuCycle Elite power supply for Eflite Charger? - 7/12/2008 4:10:57 AM
J-MICHAEL
Status: offline
Geardaddys
Can't you use the Accu-Cycle Elite to charge your 400 batts ? Or do you just have the power supply ? Just curious... I thought maybe the Accu-Cycle would perform better for you than the stock charger that came with the unit...
Anyway, good luck to ya...
Jeff
Logo 10/ Trex 450/ Cp-Pro x2/ Cx2/ Mini-Funtana X/ Typhoon2 3-D/ Aero Challenger x2/ E-Maxx,Bandit,Stampede/ Evader St Pro
       Post #: 7
RE: AccuCycle Elite power supply for Eflite Charger? - 7/12/2008 4:15:32 AM
autoart4you
Status: offline
good point J-MICHAEL! i bet he dose not have a balancer?
(in reply to J-MICHAEL)
       Post #: 8
RE: AccuCycle Elite power supply for Eflite Charger? - 7/12/2008 4:41:29 AM
Geardaddys
Status: offline
Yeah, I have the AccuCycle and I've been charging 2 lipos on it for 2 years now.. It works fine and although it doesn't have a "balance" feature, I put my 2 batteries on a friends balancer to see how "whacked" they had gotten.. They were both nearly perfect.. I was really surprised.. The accu cycle will charge the eflite battery just fine, I just wanted to be able to use the balancer every once in a while to be sure it hadn't gone nuts on me..
       Post #: 9
RE: AccuCycle Elite power supply for Eflite Charger? - 7/12/2008 5:27:56 AM
evdreamer
Status: online
There are some cheap external balancers out there that you could hook up to the Accucycle charger. I use two FlightPower balancers on my Accucycle charger and charge two batteries at once. Even though your batteries are fine now in time the balance is going to get worse. And if one cell gets over 4.2V you are gettting in the area of it lighting on fire or exploding. And the stock E-Flite charger will never fully charge the battery with my experience on the CX and CPP chargers.
Nick
Since I started this hobby money seems to keep disappearing. :)
Blade CX, Blade CP Pro, T-Rex 450SEV2
       Post #: 10
RE: AccuCycle Elite power supply for Eflite Charger? - 7/12/2008 5:44:27 AM
J-MICHAEL
Status: offline
Geardaddys~
If anything get a "Blinky" for like $25.00 bucks, and it will balance em for ya while using the Accu-Cycle. I have the Common Sense version and it works great when I do use my Accu-Cycle. It fits great for my E-Flight batts and Air-Thunder among many more. For the Thunder Power packs you need an adapter which is only a few bucks...Until I get a good balancer for my Thunder Power charger I've been balancing my lipo's with the blinky for all my heli's for awhile now...
Here it is http://www.helidirect.com/product_info.php?cPath=116_538&products_id=6927
Hope this helps,
Jeff
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to evdreamer)
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
