fg shock oil numbers?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> fg shock oil numbers? Page: [1]
Login
fg shock oil numbers? - 7/12/2008 2:18:05 PM
kryptonite5b
Status: offline
the viscosity of fg shock oils go by the thousands, ie; 4000-5000.. and standard silocone shock oils like trinity and so on go by the double digits, ie; 40wt-50wt. my question is are they the same with fg's just having a couple extra zreo's? im assuming the fg oils are silocone..wrong?.. so would a trinity 50wt be the same as an fg 5000wt?
_____________________________
sponsored by: vsmodelsport.com
scanner-rc
       Post #: 1
RE: fg shock oil numbers? - 7/12/2008 2:34:07 PM
Lars from Norway
Status: offline
A 30 wt oil is not the same as 3000wt oil from FG.I know a guy who tried 90wt oil in his dampers on his FG Marder,it was waaay to thin.And yes,its silicone
What seems to be the officer,problem?
Got all under cnotrol!
(in reply to kryptonite5b)
       Post #: 2
RE: fg shock oil numbers? - 7/12/2008 4:05:20 PM
Foxy
Status: offline
To convert US weights to European weights, take off 20% and add a zero. eg, US 50wt = 400wt Euro. This is not a precise formula though, it's an approximation ONLY. Best thing is to use euro weights, cos the best oil suppliers use them. Xray and Mugen oils are particularly good.
< Message edited by Foxy -- 7/12/2008 4:06:07 PM >
Foxy. RCU Car Forums Moderator.
"Artificial Intelligence is no match for genuine stupidity".
Check out my Large Scale Gas RC Car Vids... www.youtube.com/foxy4242
(in reply to Lars from Norway)
       Post #: 3
RE: fg shock oil numbers? - 7/12/2008 5:33:33 PM
kryptonite5b
Status: offline
got ot.. thanx foxy
scanner-rc
(in reply to Foxy)
       Post #: 4
RE: fg shock oil numbers? - 7/12/2008 10:55:48 PM
Vette09
Status: offline
if it's for your on-road, which I assume it is, use 6000 or 7000 in front and 3000 or 4000 in the rear. That's a very good starting point for an on-road on ANY surface. Most racers I know don't use anything else. I use 7000 front and 4000 rear and it works very well for my car on a loose surface and on a grippy one. With your car being a sportline, I'd recommend you go with the 6000 front and 3000 back. Oh, what springs are you using?
       Post #: 5
RE: fg shock oil numbers? - 7/13/2008 12:40:20 AM
kryptonite5b
Status: offline
hey vette. got your pm, thanx, that was some good info. im running the stock red springs.
scanner-rc
(in reply to Vette09)
       Post #: 6
RE: fg shock oil numbers? - 7/14/2008 12:54:12 AM
Vette09
Status: offline
Red springs front and rear are the hot ticket on that track. Just make sure you use the right shock oil. If you're using 50 wt oil you're gonna have serious handling problems.
       Post #: 7
RE: fg shock oil numbers? - 7/14/2008 3:05:33 AM
kryptonite5b
Status: offline
so by foxy's estamate i should be ok with running 90wt/50wt. that comes out to ABOUT 7200/4000?. ordering fg silocone just slipped my mind when i placed my fgsupply order. ive already placed the order, but im not sure if i'll get it in time for the weakend. its ok thow. thanx for your help!! jason.. the stock oil that came in my gt-40, i swear was motor oil... it was brown and smelled like mobil1 !!!!
scanner-rc
       Post #: 8
RE: fg shock oil numbers? - 7/14/2008 8:00:59 AM
Foxy
Status: offline
NOOOOO! 90 weight would be about 700, not 7000. Similarly 50wt is 400, not 4000. This is a whole different scale than the oils for small shocks.
       Post #: 9
RE: fg shock oil numbers? - 7/14/2008 3:30:31 PM
Vette09
Status: offline
Jason, I have plenty of shock oil. If you want to get the most out of your car this weekend, take your shocks off when we get to the track and I'll give you some oil for them.
(in reply to Foxy)
       Post #: 10
RE: fg shock oil numbers? - 7/14/2008 8:48:53 PM
kryptonite5b
Status: offline
hmm. ok.. im loughing at myself!!! just a slight lurning curve for me. i guess i'll see you at the track.. thanx vette!!
scanner-rc
       Post #: 11
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.672RCU1
