Battery Charging Question
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Car General Discussions >> Battery Charging Question
Page: [1]
Login
Battery Charging Question - 7/12/2008 2:44:21 PM
term_paint
Status: offline
have a very old AC/DC MRC battery pack charger. This charger just has a timer and a meter. I know when i bought this years ago most guys had to manually peak their packs with a meter. Does anyone know the procedure i would like to use this charger for a few weeks until i can replace it. Thanks and i dont want to harm my new battery packs. I have a 1600mah and a 3000 mah 7.2v packs.
As always thanks
       Post #: 1
RE: Battery Charging Question - 7/12/2008 8:30:54 PM
RC Brain
Status: offline
Is the meter to adjust the charge amperage? If it is, set it at 5 amps. That should be an okay amount for both packs. Connect a pack to the charger, and set the timer for the max amount of time. Since I can't give you an exact time to charge each pack, you will have to watch them and wait for them to reach an appropriate temperature. Wait until the pack feels slightly warmer than room temperature and disconnect it when it reaches this point. Around 110 degrees Fahrenheit is probably a safe temperature. Basically just charge the pack until it feels warm to the touch. Don't let it get hot. This is what will damage the battery cells. I hope this helps.
(in reply to term_paint)
       Post #: 2
RE: Battery Charging Question - 7/13/2008 2:11:03 AM
magnat
Status: offline
Is the Charger Nimh Safe ?? It should state so somewhere on it..
I wouldn't want to charge a Nimh on a Nicd only charger... could get messy
_____________________________
Traction: What a drag.....
(in reply to RC Brain)
       Post #: 3
RE: Battery Charging Question - 7/14/2008 7:02:55 PM
offroadbasher9
Status: offline
If it's timed, it most likely will not charge the 3000 mah nimh. I don't think I've ever seen one that does anyway....
"Drifting" - It''''s the figure skating of motorsports
(in reply to magnat)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.438RCU1
