rechargable rx pack
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> HPI Monster Truck Forum >> rechargable rx pack
Page: [1]
Login
rechargable rx pack - 7/13/2008 12:40:40 AM
sb13
Status: offline
Is there an upgrade for the Savage that allows a recharbale pack to be installed in the truck instead of using those AA batteries?
_____________________________
Scott
       Post #: 1
RE: rechargable rx pack - 7/13/2008 1:12:46 AM
twomanytoys
Status: offline
Yes. Any 6v hump pack will work. I use them in both my savages.
J et A ssisted T ake O ff
(in reply to sb13)
       Post #: 2
RE: rechargable rx pack - 7/13/2008 1:22:17 AM
sb13
Status: offline
This may be a stupid question but how do you mount it? Is there an aftermarket battery tray you use or what?
Scott
(in reply to twomanytoys)
       Post #: 3
RE: rechargable rx pack - 7/13/2008 2:03:52 AM
SportsFans
Status: offline
No stupid question. they fits in the same space as non rechargeables go. just remove the non rechargeable tray.
< Message edited by SportsFans -- 7/13/2008 2:05:02 AM >
Savage X, Savage XSS..... http://s201.photobucket.com/albums/aa70/SportsFans77/?start=all
(in reply to sb13)
       Post #: 4
RE: rechargable rx pack - 7/13/2008 2:17:30 AM
sb13
Status: offline
Do you run it through a switch and then directly to the receiver?
Scott
(in reply to SportsFans)
       Post #: 5
RE: rechargable rx pack - 7/13/2008 2:18:41 AM
sb13
Status: offline
Can you guys post a picture of your set up for me? Thanks.
Scott
(in reply to sb13)
       Post #: 6
RE: rechargable rx pack - 7/13/2008 2:33:09 AM
splcrazy
Status: offline
DDM has a 6volt flat pack with 4600mah thats awsome this is what im getting next for my savage . i might have to mod the charge port adapter wires but it will work . because this batt is intended for use on the baja5b i think.
(in reply to sb13)
       Post #: 7
RE: rechargable rx pack - 7/13/2008 2:33:53 AM
Sparco
Status: offline
if its intended for the 5b...it won't fit.
"Fighting over the internet is like racing in the special Olympics, even if you win you''re still retarded."
(in reply to splcrazy)
       Post #: 8
RE: rechargable rx pack - 7/13/2008 3:01:50 AM
newaddict
Status: offline
Just build a humppack out of 5 Sanyo 2700mah batteries (best batteries in the world....proven). I did that and I've never had a problem with my batteries running out. Remember that I'm running an lst2 which requires 2 steering servos and the ones I'm running are JR650s which are WORLDS better than the steering servo on the savage. I'm using a jr590 for throttle (overkill but I like it). 3 powerful servos and I have yet to come back home because of a discharged humppack.
Lst 2 w/ Lrp Spec 3.
(in reply to Sparco)
       Post #: 9
RE: rechargable rx pack - 7/13/2008 3:20:40 AM
splcrazy
Status: offline
quote:
ORIGINAL: got_nitro632
yeah but its not as big as you think. i wired two flat venom 6volt 1200mah packs together then mounted them on top of the plastic box no worries , the ddm batt would be a breeze to install
       Post #: 10
RE: rechargable rx pack - 7/13/2008 3:30:24 AM
sb13
Status: offline
I just ordered a 3000 mah hump pack from Horizon to use. Are you guys just hooking it up to an on off switch and then the receiver? I assume you are, makes sense.
Scott
       Post #: 11
RE: rechargable rx pack - 7/13/2008 3:40:22 AM
twomanytoys
Status: offline
The switch is already there. Just hook the pack up the same way the AA battery pack is hooked up. Thats it. Nothing else. Real easy.
(in reply to sb13)
       Post #: 12
RE: rechargable rx pack - 7/13/2008 4:09:05 AM
sb13
Status: offline
Cool, thanks.
Scott
       Post #: 13
RE: rechargable rx pack - 7/13/2008 10:32:39 AM
MikeVi
Status: offline
Will this Venom 6V 1600mAh NiMH Hump Receiver Battery fit a SavageX 4.6? I just got mine and I dont feel like spending hundreds on batteries. Any other suggestions?
(in reply to sb13)
       Post #: 14
RE: rechargable rx pack - 7/13/2008 5:10:25 PM
rclugnut10
Status: offline
yupers that'll fit nice and happy i got the 1200mha and like it lots i can get about 1.5-2 hours of running on it (i never really count)
rclugnut10
HPI SAVAGE X SS, DTX EVADER PRO, TEAM ASSOCIATED RC10B4, E Choas (in the works)
(in reply to MikeVi)
       Post #: 15
RE: rechargable rx pack - 7/13/2008 5:25:51 PM
