flyrc100
TN, USA Status: offline
Hey JG, I got mine also, they are the same ones I used to convert, so I know exactly what to do. I think you are going to find out that you don't have enough threads to bolt a prop on when you remove the black nut from the flywheel. I think you will need a proper prop hub. That and a bunch of washers dont look too good. So far as the engine mount goes its true you could bolt the engine directly onto the firewall, however, there is no good flat area for the bolt head to rest on. I guess its possible to run the bolts from inside the airplane, thru the firewall, an |
