eflite lipo info
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> eflite lipo info Page: [1]
Login
eflite lipo info - 7/14/2008 1:49:07 AM
Dragonfly2k3
Status: offline
Ok, so i noticed today that all of our venom batteries are somehow bad. I open them, they show 0.0 volts, i charge them, according to my charger they charge to 6.9v(7.2v packs) but then there is no output from them. I have decided to go with an eflite 2cell 1800mah pack which JUST fits into the mini-t tray, i may even run the dremel through once to give it a little play to make it quicker to change batteries. What is a good point to begin charging at(amp wise)? I obviously dont want to damage the cells in anyway, but am not very familiar with lipo batteries.
Also, i am currently running 16/60 on my mini-t with a cobalt b and still the motor gets hot. not as hot as it did before with the 12t pinion, but i can only hold my finger on it for a few seconds without it getting too hot after a full pack of 1/2-full throttle. My mini-tazer is still about 10*F above ambient though.
       Post #: 1
RE: eflite lipo info - 7/14/2008 1:50:33 AM
Dragonfly2k3
Status: offline
should i go to an 18t pinion? The truck will certainly be top speed fast that way, or do you think its another issue?
(in reply to Dragonfly2k3)
       Post #: 2
RE: eflite lipo info - 7/14/2008 2:17:02 AM
hyperscorpic
Status: offline
Charge at 1.8A. Unless otherwise stated, lipos should be charged at 1C.
_____________________________
Vendetta ST going all out for durability
       Post #: 3
RE: eflite lipo info - 7/14/2008 9:14:50 AM
Mini_Me
Status: online
Is your 6.0v cutoff working on your esc and are you unplugging the lipo right after you get done running? Im trying to figure out how your getting down to 0.0 volts. What charger are you using?
M18/T FAQ available on http://www.teamxray.com/
(in reply to hyperscorpic)
       Post #: 4
RE: eflite lipo info - 7/14/2008 2:32:04 PM
Dragonfly2k3
Status: offline
sorry, that was confusing wording on my parts. In the store i have venom nimh batteries, for minis, they've been there so long that they're bad haha. When i initially plug them into my charger it shows 0.0v, after about 15mins on the charger they will show 6.9v and not take any more of a charge, and because of my 6v cutoff they will work to run the steering servo but not the motor, and within a few seconds they will be below 6v and useless. Because of this i have decided to go lipo, and thus i am getting the eflite 1800mah pack as i believe it is the biggest lipo pack i can fit in the mini-t battery tray(mAh wise, not voltage wise)
(in reply to Mini_Me)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.516RCU1
