Modeltech Mach Racer Delta
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Glow to Electric Conversions >> Modeltech Mach Racer Delta Page: [1]
Login
Modeltech Mach Racer Delta - 7/14/2008 2:20:19 AM
*BUBBA*
Status: offline
Hey guys,
Well here i am, once again without the knowledge to know how to complete my project. I am looking in to the Mach Delta racer by modeltech, and I would like to know if the powerplant I have is enough, the motor I am using is a Multiplex Bl-480 6d (i know its not used very often) on a 3s lipo, its spinning a 6x5.5 apc prop. From what I've calculated its pulling about 25 amps and it has about 40oz of static thrust. How can I tell if this is enough to fly the plane? I'm not too worried about speed, but I would hate to spend the money and have it underpowered.
Heres the a link to the plane http://www.hobbypeople.net/gallery/123780.asp
Hope you can help.... Thanks
       Post #: 1
RE: Modeltech Mach Racer Delta - 7/14/2008 2:23:58 AM
jumper666
Status: offline
50 - 70 watts/lb = min for light park flyers
70 - 90 watts/lb = trainer and slow flight
90 - 110 watts/lb = sport aerobatic & fast scale
110 - 130 watts/lb = advanced aerobatic & high speed
130 - 150 watts/lb = light 3d and ducted fans
150 - 200+ watts/lb = unlimted 3D
(in reply to *BUBBA*)
       Post #: 2
RE: Modeltech Mach Racer Delta - 7/14/2008 4:23:11 AM
tIANci
Status: offline
Bubba ... with your proposed set up you will be lucky to get her to lift an inch off the ground. The Mach Racer is a speedy plane on a 46 sized glow motor. The power you giving on your motor set up is like a 15-20 sized motor. For me if I were to covert the MachRacer it will be turning a 12x10 prop at high RPMs, at least 6,500 if you want some decent speed, 8,000 RPM would be good. That will mean the system is pulling about 1,000W on a 5S set up. Pulling and not at the prop ok.
Why the 12x10? Because the plane is built for a 46 motor, usually 10" or 11" props, a 12" will clear for sure. I would go with a 4S set up as a minimum ... if you want to get crazy then a 5S set up.
Motor would be something like the AXI 2826 series, the 2826/10 for 4S perhaps. I used a DualSky 4260-5 on 5S with a 12x10 for really fast flying fun, it can kill the motor but then so what, since its cheap anyways.
_____________________________
Its nice to be important, but its more important to be nice ...
www.rcheadz.com
(in reply to jumper666)
       Post #: 3
RE: Modeltech Mach Racer Delta - 7/19/2008 6:36:24 AM
*BUBBA*
Status: offline
Wow, thanks for the replied, I had the power system already and was just seeing if this was even a plausible choice, thanks for the input, as it probably saved me some money...
(in reply to tIANci)
       Post #: 4
RE: Modeltech Mach Racer Delta - 7/19/2008 9:20:53 AM
tIANci
Status: offline
Anytime Bubba ... the internet is a great thing ain't it?
www.rcheadz.com
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.656RCU1
