Tips for Titan/Hurricane/Thunderbolt.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Giant Scale Cars >> Tips for Titan/Hurricane/Thunderbolt. Page: [1]
Login
Tips for Titan/Hurricane/Thunderbolt. - 7/14/2008 2:47:12 AM
Tonecapone
Status: offline
I am not sure if this is the proper place to post this or not but I have some interesting info concerning Thunderbolt and the Hurricane which I believe are the same.
1. Center Diff mod............... I stripped my diffs, cleaned and reshimmed them and sealed the cases with shoe goo. I did this by placing a small amount around the top of the diff cover before seating it and then after seating it I placed a small bead around the bottom before replacing the ring gear. After curing for 24 hour I removed the top drive cup and proceeded to fill it completely with Ofna 120,000 diff fluid which is the thickest I could find. It took some time to fill and I had to replace the drive cup periodicly to and spin the diff to remove the air bubbles. After putting the truck back together all I can say is HOLY CRAP!!!! it made a would of difference. This thing now moves like a bat of of hell!. The was minimal loading to the front wheels and my hurricane was giving my brothers Losi 8ight truggy a serious run for it money on a flat track. I ran it for approx 3 hours off and on and have not noticed a single leak. For anyone with a Thunderbolt/Titan/Hurricane this is a inexpensive fix that is incredible it cost me $6.99 for the diff fluid and $3.99 for the Shoe Goo.
2. Shock fluid.....In my Hurricane the stock shock fluid is like water and does not do much to dampen the hits. I did not have and of the FG shock fluid and noe was available locally so what do I do? I did what any good Hobbyist does, I went rummaging around my work shop :-) Lo and behld I found various viscosity of diff fluild for my 1/8 scale which is MUCH thick than shock fluid. After some trial and error I discover that 3000 in the front and 2000 in the rear makes this truck handle like a champ. It absorbs the bumps like it should and comes out of the turns faster than before. The heavier fluid in the front helps to kick the front up in jumps and it flies pretty even through the air. This diff fluid is available in most hobby shops that have 1/8 scale cars and is easier and cheaper to get than the FG equivalent. You will need about two bottles of each weight. There will be some left over but then there always is.
I hope these tips help someone and if you try it I think you will be pleased with the results.
Tone
       Post #: 1
RE: Tips for Titan/Hurricane/Thunderbolt. - 7/14/2008 8:04:59 AM
Foxy
Status: offline
Good tips, thanks for that.
I'd like to add...
Dogbones popping out... Some trucks have this problem, some don't. It stems from the fact that Smartech seem to have supplied o-rings in the outdrives on some models, but not others. In any case, it's a very simple fix.
Remove the lower outer hingepins on each wheel and take out the dogbones. Check for o-rings. If none are present, cut a small piece of fuel tubing tubing into 8 x 2mm pieces, hereafter referred to as spacers. Put one spacer in each diff out drive, and wheel axle. Now carefully replace the dogbone being careful not to disturb your new spacers. Use a bit of silicone oil to 'stick' the spacers in if they keep falling back out again. There ya go, no more dogbones popping out.
< Message edited by Foxy -- 7/14/2008 8:07:20 AM >
_____________________________
Foxy. RCU Car Forums Moderator.
"Artificial Intelligence is no match for genuine stupidity".
Check out my Large Scale Gas RC Car Vids... www.youtube.com/foxy4242
(in reply to Tonecapone)
       Post #: 2
RE: Tips for Titan/Hurricane/Thunderbolt. - 7/15/2008 2:16:08 AM
Cal-Torque
Status: offline
Elcon springs in the drive cups are a great fix for the dogbone issue.
They fit tightly into the cup.
(in reply to Foxy)
       Post #: 3
RE: Tips for Titan/Hurricane/Thunderbolt. - 7/15/2008 3:27:24 AM
Slammed
Status: offline
great thread
Havoc 4.6cc, FireHammer 23cc , Tmaxx HPI 21,Tmaxx 2.5,Mini LST, Cessna 182, Focus 400EP Brushless www.youtube.com/benduchi
(in reply to Cal-Torque)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU1
