BuschBarber
NY, USA Status: offline
I mentioned that I have an H9 P47-150, Fuji 32 gas engine, XP9303 with Spektrum module, and AR9000 receiver with one Remote receiver. I was flying it recently and it suddenly rolled rapidly to the Right. It is the first time I have encountered a suspected glitch with 2.4. No wind or other weather factors that might have caused the aircraft to roll like that. I rolled back to level, dropped the gear, and landed. I forgot to connect the Flight Log before turning off the radio. I did range checks, on the ground, and hooked up the Flight Log. I had over 720 fades on one antenna, over 200 fades on the other antennas, and 5 holds. The AR9000 was in the belly of the plane and the Remote receiver was on the side of the fuse |
