Low Voltage cutoff?
Tower Hobbies
Logged in as Guest
  Printable Version
FLIGHT STAND AND WORK TABLE
Seller:  martys40s
Details:   $67.50   |  9/9/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> Brushed/Brushless motors, speed controls, gear drives >> Low Voltage cutoff?
Page: [1]
Login
Low Voltage cutoff? - 7/14/2008 8:01:05 PM
Tony Gag Jr.
Status: offline
I have a question about the low voltage cutoff on an ESC. I am using a E-flite 40 amp pro switch mode ESC and a 3-cell Li-Po battery pack. It says the low voltage cutoff for a 3-cell is 9Volts. Does this mean when the batteries get down to 9volts the ESC stops supplying power to motor and is only supplying power to the receiver and servos? I ask this because I want to make the switch from 72mhz to 2.4ghz and I know the 2.4ghz stuff has had some problems when the voltage drops to low. I think the 2.4ghz(Spektrum/JR) needs at least 3.5volts to operate.
Tony
       Post #: 1
RE: Low Voltage cutoff? - 7/14/2008 8:12:23 PM
Walt Thyng
Status: offline
the short answer to your question is "Yes." Spectrum (and I think JR) have upgrade their recievers to avoid this problem and you can buy a plug in capacitor for older 2.4 systems. Or you can use a separate rx battery
WT
_____________________________
WT in Illinois
(in reply to Tony Gag Jr.)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.641RCU1
