futaba radio
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Beginners >> futaba radio
Page: [1]
Login
futaba radio - 7/14/2008 11:08:16 PM
timntrace
Status: offline
i have a futaba t6xa 6 channel computer radio i just bought in website. i cant get both daul rates to work. i checked the manual and the daul rates is set at 100%. IT IS IN AIRCRAFT MODE 1. can someone help me get the daul rate to work . thanks tim
       Post #: 1
RE: futaba radio - 7/14/2008 11:23:26 PM
cappaj1
Status: offline
quote:
ORIGINAL: timntrace
In case you don't have it, here's a link to the owner's manual
http://manuals.hobbico.com/fut/6xas-hs-manual.pdf
Is this the same one you have?
< Message edited by cappaj1 -- 7/14/2008 11:24:54 PM >
_____________________________
-Jim-
Keep thy airspeed up, less the earth come from below and smite thee.
(in reply to timntrace)
       Post #: 2
RE: futaba radio - 7/14/2008 11:25:47 PM
RCKen
Status: online
quote:
ORIGINAL: timntrace
The reason why it's not working is because the percentage set on the dual rate is how much lower low rate is than the full rate. So, if you have the dual rates set at 100% then the low rate will move the same exact distance as the high rate. But if you lower that to 60%, for instance, then the control surface will move only 60% of what the full rate does. So try lowering the dual rate setting and see if it doesn't work for you.
Ken
The take off is optional, but the landing is MANDATORY!!
AMA # 712539 www.gettingairborne.com
Moderator- Beginner''s, Sport Flying, Off-Topic, & AMA Discussions
RCU Community Moderator
       Post #: 3
RE: futaba radio - 7/14/2008 11:27:22 PM
MinnFlyer
Status: offline
When the dual rates are off, the channels are set to 100%
If the dual rates are set to 100% there will be no difference between when they are on or when they are off.
Change the dual rates from 100% to 50%, 60% or 70% and you'll see a difference
Mike B.
AMA# 42400 www.gettingairborne.com
"Those are my principles. If you don't like them, I have others." - Groucho Marx
(in reply to cappaj1)
       Post #: 4
RE: futaba radio - 7/14/2008 11:31:14 PM
gaRCfield
Status: offline
Generally you set the plane mechanically to have the greatest amount of throw in the control surfaces, and have your high rates at 100%, then set your low rates to something like 60% for easier flying. If you need more out of your plane on high rates, you can increase to 120% or something.
..this hobby is doing weird things to me...
(in reply to MinnFlyer)
       Post #: 5
RE: futaba radio - 7/14/2008 11:40:00 PM
RCKen
Status: online
quote:
ORIGINAL: gaRCfield
This is not correct. If you set the plane mechanically for the greatest amount of throw on a control surface and then increase the throw to greater than 100% in the radio you will either damage the servo, damage the linkages, damage the control surface, or create a binding that can create a large draw on the battery that will drain the battery quickly. If you need to increase the amount of throw on a control surface you need to do it mechanically on the plane, and not use radio settings as this will cause problems.
Ken
(in reply to gaRCfield)
       Post #: 6
RE: futaba radio - 7/14/2008 11:51:44 PM
timntrace
Status: offline
i lower the daul rate at 60%. fix thats how it should work thanks
       Post #: 7
RE: futaba radio - 7/14/2008 11:58:24 PM
gaRCfield
Status: offline
quote:
ORIGINAL: RCKen
quote:
ORIGINAL: gaRCfield
Ken
Oh thanks for the correction Ken. I meant to say to set the throw to the recommended settings (in the manual) and you can get a little more out of the plane using the radio. Was thinking of two things at once.
(in reply to RCKen)
       Post #: 8
RE: futaba radio - 7/15/2008 12:21:07 AM
Gary L.
Status: offline
" Was thinking of two things at once. "
I hate when that happens !!
We''re all here because we''re not all there !! AMA # 884678 Proud to be a volunteer firefighter !
       Post #: 9
RE: futaba radio - 7/15/2008 4:07:50 PM
bruce88123
Status: offline
quote:
ORIGINAL: gaRCfield
quote:
ORIGINAL: RCKen
quote:
ORIGINAL: gaRCfield
Ken
And IMO Ken SHOULD have said that it MAY cause a problem and not WILL. It won't always be bad but needs careful evaluation from plane to plane. Even 2 seemingly identical planes may have different problems.
3-D is for Monster Movies
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
