Rc18t Steering Problem
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> 1/16th, 1/18th, Mini & Micro RC Cars >> Rc18t Steering Problem
Page: [1]
Login
Rc18t Steering Problem - 7/14/2008 11:30:25 PM
sunco1
Status: offline
Well. This problem started when my stock steering servo blew out and i switched to the hs 65mg. Then i put the dp drag link in it.
The stering now is terrible. When i turn left it will turn only a little bit. And it wont recenter at all. It happens for both ways. But it turns to the left better than to the right.
I made a video. Its with the dp link removed. And just the hs65.
You can see me steer it and how it doesnt turn back.
CLICKY FOR PART 1
CLICKY FOR PART 2
_____________________________
Race ready Revo. Vendetta st. Hpi firestorm. Micro t. And a whole bunch of parts!
       Post #: 1
RE: Rc18t Steering Problem - 7/15/2008 5:33:18 AM
calvino
Status: offline
servo saver spring is probally worn out
RC18T 6800 Sidewinder Micro 2s lipo, 1980 Goldpan (needs electronics), ST-1, Slow Stick $15 outrunner combo 3s lipo †
(in reply to sunco1)
       Post #: 2
RE: Rc18t Steering Problem - 7/15/2008 4:42:15 PM
rcdude4051
Status: offline
get these::: it will fix all that 100%, had same problem and this is what i got and its perfect know
http://www.thetoyz.com/cart/thetoyz_details.lasso?id=8122&cat_name=RC18T
http://www.thetoyz.com/cart/thetoyz_details.lasso?id=10221&cat_name=RC18T
and this,,,, i can't find just these 2 pieces on thetoyz, it has the little middle piece but there on 3b@y for like 7$+ 3$ shipping....
http://www.integy.com/T7606B.jpg
my rides:
sweet rc18t,
(in reply to calvino)
       Post #: 3
RE: Rc18t Steering Problem - 7/15/2008 5:06:46 PM
maxxin2.5
Status: online
i have just that special edition drag link thing and i dont like my steering very much..
the little holes where the ball stubs go in ware out and the it creates slop and then the wheels dont re-center after a while...
owell
13 going on 14...haha
if you arent breaking anything then you arent having enough fun!
(in reply to rcdude4051)
       Post #: 4
RE: Rc18t Steering Problem - 7/15/2008 6:10:52 PM
revocrazy7
Status: offline
thax for your help guys but i tryed all of that stuff and it still dose not work. i have the metal springs, and the drag link. but there not on because it still did the same thing so anymore suggestions!!!!\\
Thanx!!!
(in reply to maxxin2.5)
       Post #: 5
RE: Rc18t Steering Problem - 7/15/2008 6:37:46 PM
peelin_out
Status: offline
you need to bore out the holes and/or shave the inside of the back "lip" sometimes on the draglink so that the parts are not rubbing too hard because that will make the steering stick and not re-center... also, make sure the middle of the draglink is not hitting the upper-deck.. that happened on my 18r and I needed to file the top of the draglink down.. when properly fitted the draglink is awesome.. but it does require some fussing with to get it all dialed in.. it's not a "plug and play" component I have found.
edit: from the videos it looks like you may have overtightened your kingpins (the screw wit the smooth part which holds the steering knuckle to the c-hub).. I did that and had the EXACT same problem.. you might need to get new steering knuckles also if the kingpin threads on them are worn out too much so that you need to torque them down to get them to stay in.. the proper adjustment on them should be tight enoght to stay in and keep slop out of the steering knuckles but not binding the steering knuckles.. they should be free to turn easily. some blue locktite is a good idea there so you don't have to torque them down too hard and they will stay put.. but you'll want to let it "set" for like 12 hours..
< Message edited by peelin_out -- 7/15/2008 6:47:32 PM >
2x RC18R, RC18T (all hopped up)
2x MLST, Micro-T (stock)
(in reply to revocrazy7)
       Post #: 6
RE: Rc18t Steering Problem - 7/15/2008 7:58:51 PM
revocrazy7
Status: offline
hey thanx for the reply peelin_out but i dont really know what your talking about so um it would help if you could maby word it diffrent or some pics. thanx a tone can't wait to get it running again its been like 3 months. maby longer. thanx.
oh and ps. im kinda new to this
(in reply to peelin_out)
       Post #: 7
RE: Rc18t Steering Problem - 7/15/2008 8:03:04 PM
westphill24
Status: offline
+1 to peelin out
I took my car apart and when I put it back together I tightened them down to much and the wheels where hard to move. I backed the screw out maybe a half turn and the wheels where great. I watched the video and thats what it looks like to me. I have the same setup and it made my steering phenominal.
Revo 2.5, RC18t, f103gt, Recoil, Mini Baja, Turmoil
       Post #: 8
RE: Rc18t Steering Problem - 7/16/2008 12:03:36 AM
peelin_out
Status: offline
quote:
ORIGINAL: revocrazy7
ok, np... if you take your front wheels off, there are two screws which you can get to, they are on the top and bottom of the C-hub, that's what the steering knuckle attaches to... the steering knuckle has the bearings and drive axle in it.. that's the part that actually turns with your wheels when you steer. the two screws that hold that to the other part of the car are the kingpins. try and backing them out a 1/4 or 1/2 turn.. see if that loosens things up.
       Post #: 9
RE: Rc18t Steering Problem - 7/16/2008 2:33:55 AM
sunco1
Status: offline
Oh yeah felas
I forgot to mention this was for matt (revocrazy7)
Its his car. He brought it to my house and we tried to fix it..
       Post #: 10
RE: Rc18t Steering Problem - 7/16/2008 6:51:59 PM
revocrazy7
Status: offline
yea thanx guys i just tryed that and it didnt work!!! but when the turn buckle are off of the steering nuckle it works ok so were do you think the prob is there!! any suggestions. oh and i did check and the sterring nuckles are very loose. but for some reason it just wont turn.... im really starting to hate this car lol please help!!!
       Post #: 11
RE: Rc18t Steering Problem - 7/16/2008 8:16:00 PM
revocrazy7
Status: offline
ok i think i almost got it now .!!!!! but the only problem now is it wont recenter. i have realized that there is is a stiffer metal spring in the pack then the one i was using. so i put that on and i put the drag link back on!!!! so i think i have narrowed it down to the servo saver. ok the servo recenters but the wheels do not. witch i thought was wired. so again what do you think it could be!!!! please help i really want to get this thing running again!!!!
       Post #: 12
RE: Rc18t Steering Problem - 7/17/2008 4:19:51 AM
peelin_out
Status: offline
well, I tried those metal saver c-springs and didn't like them because they lost their shape fast, and I had a re-center issue.. they are pretty stiff, but something about the plastic to metal rubbing didn't allow the steering lobe to center up after turning.. so I went back to a plastic c-spring with a metal sleeve around that and that did the trick for me.. I can't find it on ebay any more, but you get them with some alloy bellcrank steering upgrades for the rc18.. anyways, the combo of the plastic c-spring and that metal "jacket" around it allowed the steering lobe to re-center each time.. you might just try a plastic c-spring again just to see if your steering re-centers better, then you've found the issue.. some people cut parts of shock springs and put those around the plastic c-spring to stiffen it up.. you could try that.
http://www.myrcbox.com/rc18t_tighter%20servo%20saver.htm
that will blow the stock servo out fast, but the hs-65mg should old up well.
       Post #: 13
RE: Rc18t Steering Problem - 7/17/2008 7:13:27 AM
calvino
Status: offline
^ great link, never thought of it, i hear you can also use an 0-ring but whatever, an o-ring can slip... yep, the HS-65 can stand a direct drive (not the best idea for in a crash.....) but they are tough little guys
       Post #: 14
Page:   [1]
