Great Planes PLUMA 3D Foamie
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
Top Flite P-51D Mustang - 1/5 - RTF
Seller:  bblizzard
Details:   $1,500.00   |  11/16/2009   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> Great Planes PLUMA 3D Foamie
Page: [1] 2   next >   >>
Login
Great Planes PLUMA 3D Foamie - 7/15/2008 2:03 AM
teamscalepilot
Score: 100
Last Login: 11/20/2009
Status: offline
Just got done putting together the new GP Pluma!!! Lots of prefab done, the fuse is built, glue the stab with elevator and rudder with tape hinge. The wings are complete with taped hinges too.. LOTS of extra carbon rods in places you wouldn't of but they add extra strength the the airframe..
Check out the website for more details and manual (lots of pictures) going to use there recomended motor and ESV for outdoors. They have a different setup for indoor flying. Check out the speed brakes..
Waiting for Futaba digital servos and 2.4 FASST RX
I like it !!!
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1
RE: Great Planes PLUMA 3D Foamie - 7/15/2008 4:45 PM
teamgs
Score: 100
Last Login: 3/11/2009
Status: offline
Looks great! Now we need a flight report.
Regards,
Gary
Hide Signatures
(in reply to teamscalepilot)
       Post #: 2
RE: Great Planes PLUMA 3D Foamie - 7/19/2008 1:53 AM
qspilotcmh
Score: 100
Last Login: 11/21/2009
Status: offline
Yes a flight report would be appreciated. I am looking at purchasing this aircraft and would like to know how it flies on the recommended power system.
_____________________________
TLT 25% SU26 / OMP Edge V3 / OMP Extra Stiffy / E-Filte Extra 260 / E-Filte BYQ-YAK / GP Pulma / Lightflight BUG
Hide Signatures
(in reply to teamgs)
       Post #: 3
RE: Great Planes PLUMA 3D Foamie - 7/19/2008 4:12 AM
altavillan
Score: 100
Last Login: 10/4/2009
Status: offline
Futaba 607 Fasst is as light as any other micro rx. Especialy if you remove the case. But I see no real reason too unless you are into indoor compitition flying. I've been using a 617 and a 607 in a Charger foamy and a 27oz GP 3D plane. They don't weigh any more than a Berg 72 mhz rx.
I didn''t put the bullet in the fire and you quit talking about my mother! "Cosby, Shop Class, 1968 or so"
Hide Signatures
(in reply to qspilotcmh)
       Post #: 4
RE: Great Planes PLUMA 3D Foamie - 7/25/2008 4:28 PM
teamscalepilot
Score: 100
Status: offline
The Pluma is a great flier.. Very stable!! I set it up using the recomended throws for low, high and 3d (tripple rates) and using -35% expo..
I LIKE IT!!!!!
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to altavillan)
       Post #: 5
RE: Great Planes PLUMA 3D Foamie - 7/25/2008 4:34 PM
BarracudaHockey
Score: 105
Last Login: 11/15/2009
Status: offline
I just got one in for review, looks like a quick build.
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
Hide Signatures
       Post #: 6
RE: Great Planes PLUMA 3D Foamie - 7/25/2008 7:23 PM
3Disaster
Score: 100
Status: offline
I like mine, alot , if set up light its a great indoor plane, and can be a great outdoor plane too.
Hide Signatures
(in reply to BarracudaHockey)
       Post #: 7
RE: Great Planes PLUMA 3D Foamie - 7/29/2008 2:43 PM
qspilotcmh
Score: 100
Status: offline
What motor and battery are you using? What did the total weight come out at? I am looking to purchase on for indoor and calm wind outdoor flying and I am uncertain on the motor / battery setup.
Hide Signatures
       Post #: 8
RE: Great Planes PLUMA 3D Foamie - 8/17/2008 6:07 AM
Luv2Flyallday
Score: 100
Last Login: 3/15/2009
Status: offline
Yeah, i'm looking at this plane also... Looks nice. It looks as though both motors deliver more than a 150 watts per pound so why would you need the 28-26-1000? That motor will put out 135 watts. Thats alot for a 8-9oz plane. If i were to even think about getting the outdoor setup, i would get the 28-26-1300. It would put out 165 watts. BUT, the batterys they recommend for this plane will not offer enough amps to allow 165 watts. I guess if i get this plane, i should just get the 28-22-1000 to save weight. My only concern here is the battery. The GP 11.1v 640 battery which weights 2oz will give me 12.8amps. The GP 11.1v 300 battery which weighs 1.1 oz will give me 6 amps to play with. 6x11.1 gives me 66.6 watts which is low. I think it's worth adding an oz to give me 12.8x11.1=142.08 watts of power. That extra oz is easily carried and then some. What do you guys think? Would you though in that extra weight? The extra battery weight and extra motor weight? I would for sure use the 640mah battery but the motor.... I think not.
Hide Signatures
       Post #: 9
RE: Great Planes PLUMA 3D Foamie - 8/17/2008 2:18 PM
qspilotcmh
Score: 100
Status: offline
I am using the Rimfire 28-22-1380, Flight Power 3S 350, APC 8X3.8SF, TB9, AR6100, Futuba 3114. THE AUW is 8.7oz. I opted for the indoor setup for this winter flying, however I did fly it outdoor the other evening in no wind. It flies very light at 8.7oz and has unlimited vertical. I would think you would only want the larger motor and battery if you were planning on flying in wind, however IMO this is not the airplane for wind. It has such light wing loading it gets knocked around with the slightest breeze. Plus the landing gear looks very fragile and I would not think of landing it on grass. It does land fine on smooth blacktop.
Hide Signatures
(in reply to Luv2Flyallday)
       Post #: 10
RE: Great Planes PLUMA 3D Foamie - 8/18/2008 3:06 PM
BarracudaHockey
Score: 105
Status: offline
The review is submitted. I used the outdoor setup right off the Tower site.
It flys awesome.
The wheelpants were gone in one flight, don't bother with them. The foam is a bit fragile so it wont take a lot of abuse.
Landings on grass are doable and won't hurt the gear because you can harrier it in at next to 0 airspeed. A bit of a breeze and it will float straight down, wings level, half elevator. A bit more of a breeze and it will fly backwards.
Hide Signatures
       Post #: 11
RE: Great Planes PLUMA 3D Foamie - 8/18/2008 7:27 PM
qspilotcmh
Score: 100
Status: offline
Where is the review posted? I did not see it under the review section.
Hide Signatures
       Post #: 12
RE: Great Planes PLUMA 3D Foamie - 8/18/2008 7:47 PM
BarracudaHockey
Score: 105
Status: offline
It was submitted last week, its usually a week or two before it gets final formatting and posted to the magazine section.
Hide Signatures
       Post #: 13
RE: Great Planes PLUMA 3D Foamie - 8/18/2008 7:57 PM
qspilotcmh
Score: 100
Status: offline
Great thanks! I may try the harrier landing tonight.
Hide Signatures
       Post #: 14
RE: Great Planes PLUMA 3D Foamie - 8/19/2008 2:40 AM
Luv2Flyallday
Score: 100
Status: offline
Well cool. Love to see that review soon. By the way, what kind of flight time can be expected of a 300mah battery?
Hide Signatures
       Post #: 15
RE: Great Planes PLUMA 3D Foamie - 8/19/2008 2:04 PM
qspilotcmh
Score: 100
Status: offline
I am using the flight Power 350MAh battery which is lighter and a higher C rating than the GP 300MAh battery. I am getting 6:30 minutes of mixed flight including hovering.
Last night I was coming out of a flat spin and my plane kept turning. I think the rudder servo failed or my spectrum locked out (which is unlikely since I was very close to the plane). Anyway when these planes hit the ground hard they are a total loss. Oh well time to spend $50 for another.
Hide Signatures
       Post #: 16
RE: Great Planes PLUMA 3D Foamie - 8/19/2008 10:33 PM
Luv2Flyallday
Score: 100
Status: offline
Thanks for the flight time. Wow, that sounds great. Looks like i'll get that battery. Only one question, How do you balance it without the v-balancer? A regulare thunder power balancer??
Hide Signatures
       Post #: 17
RE: Great Planes PLUMA 3D Foamie - 8/21/2008 12:32 PM
qspilotcmh
Score: 100
Status: offline
quote:
ORIGINAL: Luv2Flyallday
I use a Cellpro Charger. I have two of them and they work great for all my lipos which total 19 batteries.
Hide Signatures
       Post #: 18
RE: Great Planes PLUMA 3D Foamie - 8/24/2008 4:26 AM
wc524
Score: 100
Last Login: 4/8/2009
Status: offline
This plane is awesome, by far one of the best tracking foamies I have flown EVER. I did the flight for the RCU review and it only took one flight to fall in love with this plane and its performance. The power setup was CRAZY powerful!!! Knife Edge for this plane is out of this world. If you can't High Alpha knife edge with this plane you need to try another hobby because it is just way to easy. Be careful not to give too much rudder as it is very powerful and before you know it you are half way around in a KE Loop heading back for the ground. When I buy another foamy this one is next on the list. 10 out of 10 for flight performance and it floats like no other foamy for ultra-soft landings.
- Parker Gilbert
Hide Signatures
       Post #: 19
RE: Great Planes PLUMA 3D Foamie - 8/27/2008 6:43 PM
wc524
Score: 100
Status: offline
When the review comes up remember that this was my first flight with the plane so try not to be too critical. RCU should have the review and video up later this week. I'm looking forward to reading it and watching the video.
- Parker Gilbert
RRE Models
http://www.rremodels.com
< Message edited by wc524 -- 8/27/2008 6:55 PM >
Hide Signatures
(in reply to wc524)
       Post #: 20
RE: Great Planes PLUMA 3D Foamie - 8/27/2008 8:43 PM
BarracudaHockey
Score: 105
Status: offline
Second time you flew it
Hide Signatures
(in reply to wc524)
       Post #: 21
RE: Great Planes PLUMA 3D Foamie - 8/27/2008 8:52 PM
wc524
Score: 100
Status: offline
Flying in circles doesn't count in my book.....only good 3D and IMAC. Plus the battery wasn't topped off. I'll wring that thing out this weekend.
- Parker Gilbert
RRE Models
< Message edited by wc524 -- 8/28/2008 10:17 PM >
Hide Signatures
       Post #: 22
RE: Great Planes PLUMA 3D Foamie - 9/10/2008 4:12 AM
Arizona Flyer
Score: 100
Last Login: 11/6/2009
Status: offline
This was my first foamie and had it since it first came out. Easy build, no major complaints other than the gear. Able to do rolling (harrier) circles that look like I know what I am doing, knife edge loops, easy to hover, plenty of power and great flight time on the outdoor setup. I am the type to want more power so I was hesitant about buying a stock setup, however GP got this one right. Other than the surge, I wouldn't change the motor/battery setup at all. About the gear, since the aileron servo sticks out the bottom, you pretty much need the gear, however after several landings, they like to twist around. After lining the wheels back up and gluing it several times, the slots became pretty worn out. I tried to solve the problem by grabbing it out of a hover. That worked pretty good until I slapped the plane out of the air and crashed. Pretty fragile, took some time to put it back together after that. I got my money's worth so have no problem buying another. Instruction manual had one oops as it wants you to cut the aileron push rods to 2.5 inches instead 6 something. Luckily that seemed weird so I didn't do it. Good thing, would have needed to buy more carbon fiber. Emailed support to let them know but they never acknowledged it. Oh well...
Question to you electric guys, the motor surges a bit at full power, especially after a couple minutes flying. Then when the battery is about done, it surges at half throttle so good indicator to land. Someone told me they thought the ESC may be a bit small. Does this sound right?
Hide Signatures
(in reply to wc524)
       Post #: 23
RE: Great Planes PLUMA 3D Foamie - 9/10/2008 2:21 PM
BarracudaHockey
Score: 105
Status: offline
There's an addendum that covers the pushrod length but you'd have to be pretty green not to realize that the measurment is wrong.
Hide Signatures
(in reply to Arizona Flyer)
       Post #: 24
RE: Great Planes PLUMA 3D Foamie - 9/22/2008 8:32 PM
BarracudaHockey
Score: 105
Status: offline
The review went live on Sunday.
http://www.rcuniverse.com/magazine/article_display.cfm?article_id=1032
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.141RCU1
