FalconWings
TX, USA Status: offline
Jose, mine hasn't flown..........waiting on a Jet Central Rabbit! My rudder seems to work fine on the ground. My rudder post seats considerably deep inside the rudder base. I get about 1/3" throw total each side. On my Tamjets F-16, the linkeage is similar but on my particular model is not setup as good as on my JL. I have not had an issue yet inflight. However...... ........on JL kit the Aluminum rudder servo mount is weak and I could see it bowing in flight, moving the servo down and loosening the post off of the rudder base. This would lead to what Dr Doom is describing. Scary! I'll give it a try the way it is and keep a pretty close eye on it. David
_____________________________
Never argue with an idiot. They drag you down to their level and try to beat you with experience.
