Adui
OR, USA Status: offline
Um.. Probably, so long as you dont charge at a real high rate. It has the right voltage, my concern is the current. That PS only puts out 5 amps. The charger you list is capable of charging at 5 amps, so its going to need about 7 amps (guestimate) to do it safely. I suppose if its what you have you could make it work, just dont try charging over about a 2 amp rate. If you have an old PC power supply laying around, the desire to tinker, and a bit of knowledge, you could easily convert it to a +12v -12v +5v and +3.5v supply. I only pu the +12v on mine, but with a 350 watt computer supply I get as much as 15-17 amps (According to the PS label it gives 17A at 12V.) Since my chargers max draw is 7A I think I have plenty. Disclaimer: Do not attempt this if you dont have some electrical knowledge, or arent comfortable with it. These things do contain dangerous load voltages at currents that can cause injury or even death if you touch the wrong component when it has a charge! (If you dont know which ones I am speaking of you dont have the knowledge)
_____________________________
Chance favors the prepared mind. ~Louis Pasteur~
