Does anyone use Mobil Jet Oil II?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Jets >> Does anyone use Mobil Jet Oil II?
Page: [1]
Login
Does anyone use Mobil Jet Oil II? - 7/15/2008 6:01:39 PM
tralalala
Status: offline
Hi guys,
I got my hands on a complimentary quart of Mobil Jet Oil II. Is this oil adequate? It says it meets 23699, but not to the latest revision. It may be Mobil is just lazy to revise their packaging. I also have some Aeroshell 500 on the way, but I figure I'd not let this quart go to waste.
My turbine is a Wren.
Thanks.
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: Does anyone use Mobil Jet Oil II? - 7/15/2008 6:12:05 PM
seanreit
Status: offline
I use it a lot on Artes, and Jetcats.
(in reply to tralalala)
       Post #: 2
RE: Does anyone use Mobil Jet Oil II? - 7/15/2008 6:32:23 PM
Jet Lag
Status: offline
Used it for years on AMT,Ram,and Jet Cat engines.Never had a problem with bearings or clogged injectors.Just don't inhale the toxic exhaust fumes or let your skin absorb the oil.Not recommended.
       Post #: 3
RE: Does anyone use Mobil Jet Oil II? - 7/15/2008 6:34:54 PM
GreenAcre
Status: offline
I use it all the time also. Never an issue
(in reply to Jet Lag)
       Post #: 4
RE: Does anyone use Mobil Jet Oil II? - 7/15/2008 6:35:08 PM
Harley Condra
Status: offline
Revision F of MIL-PRF-23699 adds a C/I (corrosion preventative) specification for qualification to MIL-PRF-23699.
This revision has nothing to do with lubrication qualities, low/high temperature limits, etc.
Any oil qualified to MIL-PRF-23699 (any revision letter) is acceptable for use in our engines.
_____________________________
Harley Condra
BVM REP, JetCat REP
(in reply to seanreit)
       Post #: 5
RE: Does anyone use Mobil Jet Oil II? - 7/15/2008 9:11:06 PM
Shok
Status: offline
been using it exclusively since 2003, never had a problem
Ronnie
Jetmach, Flyeagle, JetCat Sales
www.laser-design-services.com
(in reply to Harley Condra)
       Post #: 6
RE: Does anyone use Mobil Jet Oil II? - 7/15/2008 9:25:11 PM
Achillesfilho
Status: offline
Using since 2004 without problem. Very good .
(in reply to Shok)
       Post #: 7
RE: Does anyone use Mobil Jet Oil II? - 7/15/2008 10:27:25 PM
MaJ. Woody
Status: offline
Always.
Dom
Team FeiBao
(in reply to Achillesfilho)
       Post #: 8
RE: Does anyone use Mobil Jet Oil II? - 7/15/2008 11:12:28 PM
craigdyer
Status: offline
Used since 1999...Artes, Wren and Jetcat...All still good.
Regards, Craig
(in reply to MaJ. Woody)
       Post #: 9
RE: Does anyone use Mobil Jet Oil II? - 7/16/2008 1:50:45 PM
c/f
Status: offline
Using it since 2001, 6 AMT, 2 SWB.........
(in reply to craigdyer)
       Post #: 10
RE: Does anyone use Mobil Jet Oil II? - 7/16/2008 2:42:26 PM
Dave Wilshere
Status: offline
Mobil Jet II is the best oil-The only oil Team Motors & Rotors use.
It stays mixed with our fuels better and has a high spec than many other oils.
Dave Wilshere
Motors & Rotors. UK JetCat, BVM, Airworld, Eurokit & Graupner agents. Comp ARF Rep UK.Pull Over Products.
(in reply to c/f)
       Post #: 11
RE: Does anyone use Mobil Jet Oil II? - 7/16/2008 3:31:04 PM
WrenTurbines
Status: online
quote:
ORIGINAL: tralalala
Hi guys,
Thanks.
Your Wren will be very happy with that!
Sara Parish
Wren Turbines
       Post #: 12
RE: Does anyone use Mobil Jet Oil II? - 7/18/2008 3:37:02 AM
tralalala
Status: offline
Thanks for the response everyone, as well as the comforting affirmation from Wren.
BTW, I've always wondered why there isn't a Wren Turbines dedicated forum in the Turbine Clinic section?
(in reply to WrenTurbines)
       Post #: 13
RE: Does anyone use Mobil Jet Oil II? - 7/20/2008 5:22:16 PM
tralalala
Status: offline
Do you guys have a better ideas for opening and storing the oil? We definitely don't need to use a full quart at a time, so do you guys store your oil? If so, in what container? Also, do you use the jab-in spouts like in the oldens days? Or just two punctures and let the oil glug out?
       Post #: 14
RE: Does anyone use Mobil Jet Oil II? - 7/22/2008 4:41:16 AM
c/f
Status: offline
I have 2 5 gal kero containers, this allaows me to always use a full quart to 4.75 gals kero, all my turbines same mix. Using two containers I can always have one of the two empty.
       Post #: 15
RE: Does anyone use Mobil Jet Oil II? - 7/22/2008 5:18:53 AM
