Lanier SeaBirdgluing plastic
Tower Hobbies
Logged in as Guest
  Printable Version
Hot Bodies Cyclone RTR Sport Race Car
Seller:  Erick Royer
Details:   $225.00   |  8/27/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Beginners >> Lanier SeaBirdgluing plastic
Page: [1]
Login
Lanier SeaBirdgluing plastic - 7/15/2008 6:41:12 PM
goirish
Status: offline
I am assembling a Lanier SeaBird that almost the entire thing is plastic. It came with a very small bottle of what they have labeled aero-cement. When one applies it to a surface it seems to make the surface soft so that when you put the other piece on it, it kinda welds the two together. Problem is: if you leave the cap off the liquid evaporates very quickly and now I don't have enough left to finish the project. Any ideas what this is and where I might buy some more. It says it contains Ketones, what ever that is.
< Message edited by goirish -- 7/15/2008 6:42:25 PM >
_____________________________
(\__/)
       Post #: 1
RE: Lanier SeaBirdgluing plastic - 7/15/2008 6:44:11 PM
r2champion
Status: offline
Could it be as simple as PVC Cement for pipes?
My intials are "RC", I guess it was meant to be!
(in reply to goirish)
       Post #: 2
RE: Lanier SeaBirdgluing plastic - 7/15/2008 6:50:37 PM
RCKen
Status: offline
PVC cement will destroy the plastic on the plane. What you need it cement designed for this type of plastic. The best cement is called IPS Weld-on #4. You can buy small bottles of it at any hobby shop that sells plastic models. If you can't find it at a hobby shop you can go to a glass shop, the type that replace windows. They use it for working with Plexi-glass. You should be able to buy a quart of it. But as you already know, make you leave the lid on it. Transfer a little bit of it in to a smaller bottle to use while working on the plane.
Ken
The take off is optional, but the landing is MANDATORY!!
AMA # 712539 www.gettingairborne.com
Moderator- Beginner's, Sport Flying, Off-Topic, & AMA Discussions
RCU Community Moderator
(in reply to r2champion)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU1
