O no!
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Beginners >> O no!
Page: [1]
Login
O no! - 7/15/2008 9:06:21 PM
Shockdriver
Status: offline
iwas flying my t-34 mentor foam build and i put in a brushless outrunner it was flying beautifully but it started to get away from me so i tryed to bank left but the nose went high like it would be in a knife edge i let off the power and i was able to turn again but when i gave it power it did the same thing so i was bringing it in for a landing and since i couldnt give it power i had to dead stick unfortunatly i stalled and smack the pavement i was able to fix the plane with some epoxy and packing tape love those foamys. So can anyone tell me what the heck was going on.
       Post #: 1
RE: O no! - 7/15/2008 11:04:27 PM
opjose
Status: offline
It's hard to say.
Your ESC may have overheated ( try a slightly smaller prop ), you could have overdrawn the battery, you may have a bad servo, a bad connector, etc.
The plane should be static tested by running it at 90% throttle and moving the controls until it hits the cutoff, then observing the behaviour of the control surfaces while you do so.
Of course it would be much more helpful to have some specific info too...
- What motor, battery, prop, drive and ESC.
- AUW of the plane with the battery in place.
- What RX and TX.
etc.
_____________________________
Build em'', fly em'', crash em'' and build more.
(in reply to Shockdriver)
       Post #: 2
RE: O no! - 7/16/2008 12:14:07 AM
hogflyer
Status: offline
Just a suggestion: use punctuation – it makes reading a lot easier.
Sounds like you overheated the ESC. Some ESC’s will barely handle 3 servos and the motor, and if you go to high power levels you’ll overheat it. You may have to go to a voltage regulator for the receiver to allow more current to the servos than the ESC will allow. Have you put a watt meter on it to see what your power level is your pulling through it?
They guys in the electric forums can probably nail this down real quick.
Hogflyer
Flight Training Coordinator - Wichita Radio Control Club - AMA Intro Pilot
www.wichitaradiocontrolclub.org AMA 47317
(in reply to opjose)
       Post #: 3
RE: O no! - 7/16/2008 12:15:04 AM
Sneasle
Status: offline
It's also possible his motor mount is loose: "but the nose went high like it would be in a knife edge i let off the power and i was able to turn again but when i gave it power it did the same thing"
       Post #: 4
RE: O no! - 7/16/2008 4:04:42 AM
Shockdriver
Status: offline
it is an 8x6 prop, a 1750kv brushless out runner, a 18a brushless esc, 11.1v lipo, and 3 9-gram servos.
< Message edited by Shockdriver -- 7/16/2008 4:05:57 AM >
(in reply to Sneasle)
       Post #: 5
RE: O no! - 7/16/2008 4:23:37 AM
Shockdriver
Status: offline
i did the static test, all controls were ok, but the engine got really hot. Im going to let it cool tonight and try again in the morning. Thanks for all the help.
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.516RCU1
