clutch nut help
Tower Hobbies
Logged in as Guest
  Printable Version
Wheely King 14mm Hex Wheel Extensions - RTR
Seller:  wheelextensions
Details:   $20.00   |  8/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> clutch nut help
Page: [1] 2   next >   >>
Login
clutch nut help - 7/16/2008 1:16:04 AM
Townsley
Status: offline
hey, im installing my new jammin jpx .21 engine. and im putting the clucth shoes on, but the springs dont fit in the little crevess thing in the clutch nut. ( i got the clucth nut when i baught my car, it came with soem extras.) i dont think the clutch nut is the right shape or size or whatver. the clutch shoe springs are up to high, instead of fitting in the middle of the clutch nut where its suppose to. the clutch nut is kind of shaped like a bullet.
is this what i need?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXHMG0&P=ML
what are the silver things that come with that one? what are they for? i noticed alot of clutch nute come with like a shaft, all i have is the nut. do i need the shaft part? i dont understand what its for. let me know if you dont understand what im talking about..and ill try to get a picture.
_____________________________
jammin x1 crt truggy; jammin x1 cr fte buggy, jammin jpx .21, dx2 ;hyper 7; playstation 3.
       Post #: 1
RE: clutch nut help - 7/16/2008 1:25:12 AM
hrdcoreglf
Status: offline
It sounds like you have a mugen flywheel nut. Yes the Ofna should work with the Jammin engine.
Wisdom is only as good as the person you give it to.
(in reply to Townsley)
       Post #: 2
RE: clutch nut help - 7/16/2008 1:26:33 AM
hrdcoreglf
Status: offline
What flywheel are you running?
(in reply to hrdcoreglf)
       Post #: 3
RE: clutch nut help - 7/16/2008 4:25:24 AM
Townsley
Status: offline
im using a standard size flywheel. 3 shoe.
       Post #: 4
RE: clutch nut help - 7/17/2008 1:55:07 AM
Townsley
Status: offline
omg, i never knew it was that hard to put a clutch assembly together. lol is there a way to tighten the clutch nut withought having the pistion move? i cant get the flywheel tight because the pilot shaft just turns and cant get the flywheel tight.
       Post #: 5
RE: clutch nut help - 7/17/2008 1:59:51 AM
rpg711
Status: offline
you could always buy a flywheel wrench...
       Post #: 6
RE: clutch nut help - 7/17/2008 4:00:30 AM
INTEGRA
Status: offline
a Zip tie through the exhaust port ushally works for a sticky crank nut.....a flywheel wrench will be of No use in this situation rpg711.
http://s150.photobucket.com/albums/s102/davidmoxley123/
http://s49.photobucket.com/albums/f285/TrUInTeGrA123/
(in reply to rpg711)
       Post #: 7
RE: clutch nut help - 7/17/2008 4:19:33 AM
youwish16
Status: offline
you can get a piston locking tool or you could use channel locks to grab the flywheel and then tighten the nut
http://cgi.ebay.com/Integy-Team-Piston-Lock-for-Nitro-Engines-INTC22331_W0QQitemZ220246083910QQihZ012QQcategoryZ34061QQrdZ1QQssPageNameZWD1VQQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Losi 8ight w/ RB S3II L2G,Avid Bearings,Dynamite Clutch Shoes & Pipe,Sprektrum Radio,Ace Servos,Team Sidewinder,Bad Horsie
(in reply to INTEGRA)
       Post #: 8
RE: clutch nut help - 7/17/2008 4:33:37 AM
Townsley
Status: offline
no, a flywheel tool, or grabbing the flywheel will not work in this situation. what i mean is...the pilot shaft is turning but the flywheel is not stuck on the collet (however its spelled) so it doesnt do any good to hold the flywheel because the pilot shaft just turns the pistion withought even tightning the nut. its kind of hard to explain.
but anyway..
INTEGRA..how would i go about a zip tie through the exhaust port?
(in reply to youwish16)
       Post #: 9
RE: clutch nut help - 7/17/2008 4:42:10 AM
hrdcoreglf
Status: offline
It actualy sounds like you either need a new collet or you need to shim it.
       Post #: 10
RE: clutch nut help - 7/17/2008 4:56:04 AM
INTEGRA
Status: offline
U guys dont have a CLUE....the nut is sticking on the crank and NOT allowing him to tighten down the nut....so holding the flywheel will do him NO GOOD if there isnt anything holding the flywheel to the crank..IE the collet......Townsley...take a big ziptie and stuff it in the exhause port and close it on the tie....then go ahead and tighted the nut as needed....he DOES NOT need a New collet or need to shim anything if not needed.
o and BTW piston locking Tools ARE NOT i repeat NOT for removing the flywheel or the nut....all they do is transfer the stress on to more delicate parts...like the con rod and bushing....i would advise Against a piston locking tool.
< Message edited by INTEGRA -- 7/17/2008 4:57:42 AM >
       Post #: 11
RE: clutch nut help - 7/17/2008 5:03:35 AM
Townsley
Status: offline
hey thanks integra. i will have to try that. so do i just take one end of a big zip tie and shove it in the echaust port and then crank the nut? will it damage the piston any? sounds harsh but i guess it could work. thanks for the info
       Post #: 12
RE: clutch nut help - 7/17/2008 5:07:03 AM
INTEGRA
Status: offline
quote:
ORIGINAL: Townsley
ive snapped off the heads of Ties before with the exhaust port...I would'nt be too worried...Just DO NOT rely on the tie to crank down the nut...use some channel locks and do it properly.
       Post #: 13
RE: clutch nut help - 7/17/2008 1:42:12 PM
rpg711
Status: offline
I thought he was trying to get the clutch nut on and the flywheel was spinning the pilot shaft? no?
This says that he wants to tighten the clutch nut without having the piston move, easilly done with a flywheel wrench holding the flywheel and then just using a normal wrench to tighten nut.
INtegra you wrong... hehe
< Message edited by rpg711 -- 7/17/2008 1:43:50 PM >
       Post #: 14
RE: clutch nut help - 7/17/2008 2:48:37 PM
INTEGRA
Join
