Gary Allen 1/4 Scale Fokker D-VII
My Feedback: (13)
I have started to build the Gary Allen designed ¼ scale Fokker D-VII, the plans are from / available thru M.A.N. I have worked with Ed @ Laser Works to produce a laser cut short kit for this plane. The laser cutting is right on and of the best quality. I have also obtain some scale goodies from Glenn(GTM) also, scale Fokker aluminum stream-line tubing, seat, ammo box and various strut and scale Fokker hinges. I will also be using his 4 color Lozenge covering. I’m modeling the D-VII after the reproduction plane built by the folks @ Memorial Flight, Ernst Udet’s F 4400/18. Enclosed are a few photo’s of the laser short kit if anyone is interested and a profile of the plane I’m modeling. I’m currently finishing up the fuse sides and will post some more photos soon, there are so many good D-VII builds plus the lack of time I plan on keeping this build thread “light-weight” so to speak. Will post updates when time permits. A few URL’s are:
Ed @ Laser Works- http://www.lazer-works.com/main.html
Glenn (GTM)- http://www.flygtm.com/
Memorial Flight- http://memorial.flight.free.fr/fokkerDVIIuk.html
dee333 (08-21-2020)
RE: Gary Allen 1/4 Scale Fokker D-VII
Hi Flying Wires,
That looks like a nice kit. He doesn't list this in the catalog, does he produce it if you ask him? I just got the parts for a 1/4 scale Siemens D.III from him.
Lyle
Lyle
I am setting up to build this plane from these plans but have a couple of issues with the wing ribs. No template for the #1 rib! I assume it is the same as #2 with some (what) differences? Where is the template for the tip rib, #13, not the #12 rib. Thank you.
Stephen
Stephen
On the plan W2 shows the last part of the TE cut off. That is W1.
The main wing sheet shows the ribs for the left side of the top wing labelled wrongly. The right side is correct and matches the ribs on the ribs sheet.
My question for people is that jig for the bottom wing appears to be incorrect. It makes the bottom of the lower wing flat. Looking at three views of the DVII the top of each wing is flat, with the bottoms raising up, not the other way round which is how the plan seems to be??
Looking at photos of Gary Allen built models the bottom wing appears to be incorrect, and appear to have been build using the jig shown.
Has any body else noticed this? Is this an error with Gary's design if one is trying to be a purist? Has anybody worked around this problem?
Suggestions and advice welcomed...
