Balance charger.....
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric General Discussion >> Balance charger.....
Page: [1]
Login
Balance charger..... - 7/16/2008 10:57:47 AM
legine
Status: offline
Hey guys im trying to charge my 11.1v 2200mah lipo with the Esky balancer charger, ive got a decent charger but i know its good to balance charge your batteries every now and then. Its says on the charger it has a 0.8A output, so does this mean it should charge for roughly 2 1/2 -2 3/4 hours??
It says in the charger instructions: CAUTION: CHARGE SHOULD NOT EXCEED 120 MINUTES in big red writing so thats kind of worrying me.
Thanks, Daniel
       Post #: 1
RE: Balance charger..... - 7/17/2008 1:54:43 AM
Matt Kirsch
Status: offline
Your math is spot on.
It won't hurt the battery to take longer than 2 hours to charge. The warning on the charger may be intended for charging batteries at 1C, or it may be an issue of duty cycle; the charger needs to cool down after 2 hours of continuous running.
What you may want to do is use your main charger to boost your packs up to about 3/4 charge (about 30 minutes, but not important to get it perfect) and then finish it off on your esky charger.
(in reply to legine)
       Post #: 2
RE: Balance charger..... - 7/17/2008 6:50:12 AM
legine
Status: offline
ok thanks
(in reply to Matt Kirsch)
       Post #: 3
RE: Balance charger..... - 7/18/2008 8:56:22 PM
Sir Raleigh
Status: offline
Slow charging at the end of the charge cycle is the best way to go.
For example, you don't continue running a water tap at full bore when you want to fill up a glass with water without spilling a drop. You want to slow down the water flow as the glass gets full so you won't spill any water.
Your esky charger might do that for you already.
_____________________________
Bill
       Post #: 4
RE: Balance charger..... - 7/19/2008 1:52:32 AM
legine
Status: offline
my proper charger does that, it goes down slowly in 0.01A incriments until it reaches full charge.......
I dont know whether the Esky charger does that.
Thanks, Daniel
(in reply to Sir Raleigh)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU1
